1 Pages (8 items)
numeric display - numeric display - Messages
Hello. Tell me, please, is it possible to see the set numerical values when calculating formulas in the program? I mean, instead
of
a = 5, b = 6,
a + b = 11
see a = 5, b = 6,
a + b = 5 + 6 = 11
of
a = 5, b = 6,
a + b = 11
see a = 5, b = 6,
a + b = 5 + 6 = 11
FYI there has been some discussion about this feature in the past.
https://en.smath.com/forum/yaf_postst23575_Substitution-Optimization.aspx
Also a function proposed here: https://en.smath.com/forum/yaf_postsm78024_substitute-variables.aspx#post78024
WroteFYI there has been some discussion about this featurein the past.
https://en.smath.com/for...tution-Optimization.aspx
Also a function proposed here: https://en.smath.com/for...variables.aspx#post78024
But there is no solution for this request there...
There is also this topic.
https://en.smath.com/forum/yaf_postst21565_Show-values.aspx
What you seek is won't be simple, as you requested and applicable however.
This situation is explained in detail by mkraska at the link above.
Greetings,
Alvaro has built a function to address this feature request:
Note: it has a little bit of a learning curve, but is worth considering never-the-less.
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
WroteNote: it has a little bit of a learning curve, but is worth considering never-the-less.
I don't see the result in the attached screenshots of how it works. A jumble of formulas where there is no clear answer.
1 Pages (8 items)
