Matrix Data
Matrix Data - Getting the wrong information - Messages
#1 Posted: 2018/4/12 16:33:22
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
I need the information for 1 pipe diameter smaller ... sigh, I hate programming
PipeVel.sm (10.74 KiB) downloaded 974 time(s).
#2 Posted: 2018/4/12 18:57:52
Smath is like Mathcad ... etc almost dead w/o programmed utilities.
#3 Posted: 2018/4/12 20:43:16
I hate programming
Model your pipe from inspired working document.
Inst_Colebrook Pipe Data.sm (59.38 KiB) downloaded 1052 time(s).
#4 Posted: 2018/4/13 16:45:34
CBG
CBG
78 likes in 312 posts.
Here is a solution
PipeVel_CBG.sm (8.94 KiB) downloaded 1039 time(s).
Carlos
ElSid 2018/4/13 17:33:00
#5 Posted: 2018/4/13 17:18:30
Ruben Sidranski
Ruben Sidranski
Muchas gracias Carlos. Lo que no podia ver es la indice else --> index.j:1 Handaba pensando en algo similar para retener el numro viejo, pero nada se me vino a la mente.
Ruben
#6 Posted: 2018/4/13 17:25:39
CBG
CBG
No hay de que Ruben. Recibe un cordial saludo.
Carlos
#7 Posted: 2018/4/13 22:01:39
CBG
CBG
Ruben: A slightly more complicated algorithm, which supports several speeds and several flows.
PipeVel_CBG_R1.sm (14.85 KiB) downloaded 1059 time(s).
Carlos
#8 Posted: 2018/4/14 10:07:09
Ruben Sidranski
Ruben Sidranski
Interesting. I was looking at modifying your other code ... this is better inspiration.
I'm looking at sizing pipe at low flow, then calculate velocity, fixed pipe dia, at a higher flow. With your original code, I set this up in two steps to look at VFD driven system.
#9 Posted: 2018/4/14 14:58:53
I'm looking at sizing pipe at low flow, then calculate velocity, fixed pipe ID, at a higher flow.
TW, Tanks Carlos ... lovely code.
Elsid, about your request:
That's what "Colebrook Pipe Data" [post 3] does.
1. For industrial projects, we measure MassFlow, not volumetric
... volumetric is for simple/primitive municipal water work.
2. "Colebrook Pipe Data" in based on 100 m, pipe length.
3. Pipe sizing is like valve sizing: trial/error,
... mostly wrt "Nominal" design conditions.
4. Convert your input data from SI to US
5. post convert back from SI to US.
#10 Posted: 2018/4/15 10:17:34
Ruben Sidranski
Ruben Sidranski
Jean,
I tend to deal in "volumetric is for simple/primitive municipal water work." And hydronic systems.
#11 Posted: 2018/4/15 10:52:33
Jean,
Hydronics is the use of water as the heat-transfer medium in heating and cooling systems. A hydronic piping system is used to circulate chilled or hot water with the connections between the piping and the terminal units made in a series loop.
Whatever "Hydronic" is hot/cold, the water has properties wrt to MASS.
Reverse Engineering in your proposal does not solve project not understood from the onset.
