Using while loop rather than for loop
Using while loop rather than for loop - Messages
#1 Posted: 2021/3/25 06:21:23
hanskl
hanskl
7 likes in 158 posts.
Can someone help me change my for loop to a while loop?
Also, there a few uses of "programming" functions in the sheet (for loop, sums etc.). What are the best practices for use in indexes? Can I use "i" for all the programming functions, or should I use a new letter every time?
Best regards,
while loop.sm (22.54 KiB) downloaded 1072 time(s).
#2 Posted: 2021/3/25 10:15:38
1,443 likes in 2,935 posts.
while loop repeats itself as long as the condition (1st argument) it's true. So you need that it's true before the loop starts to run it at least once AND a modifier inside the loop to change it when some criterion is met.
In your example, you migth implement it like this:
you can even move the i<100 check inside an infinite loop loop
#3 Posted: 2021/3/25 10:47:51
hanskl
hanskl
Davide,
Thank you for the suggestion. The condition for continuing the loop should be (sum(PS.i))<(sum(PS.0)).
For this kind of iteration, does one make more sense over the other?
Best regards,
#4 Posted: 2021/3/25 17:33:20
When working with while you have to focus mainly on how to stop the loop. If there is always a convergence, then you are fine. But if you get stuck in an infinite loop the program might crash. So be careful if you plan to not cap the number of iterations.
#5 Posted: 2021/3/26 14:25:48
hanskl
hanskl
Are there any advantages to a while loop versus a for loop?
Do you have some tips/insight to the question regarding using the same letter over and over again in loops, sums etc.?
Best regards,
#6 Posted: 2021/3/26 16:17:42
1. Are there any advantages to a while loop versus a for loop?
2. Do you have some tips/insight to the question regarding using the same letter over and over again in loops, sums etc.?
Document would help, as you may have specific case loop.
1. Golden ratio is a self iterative While solver min/ax all at once
2. Inverse(f,L,H,N) is a simple forLoop as it invokes an auto-iterative solver
3. Critical region is a While of two variables [x,y].
Enjoy ... Jean
Golden ratio QUICK.sm (43.03 KiB) downloaded 1027 time(s).
