1 Pages (10 items)
Units in variables from a matrix - Messages
Hi
I have a dataset (using Excel-file as a source) from where I get values with vlookup, but I am unable to set units properly.
Values retrieved from a matrix have these square brackets around them [], and it makes working with units really difficult.
I was able to convert mm to m (my database has plain values, but they are supposed to be mm). But next step is to display final results in kN/m, but I keep getting kg/s^2.
I am able to remove units completely and display the correct result without units displayed, but this is suboptimal.
EDIT: I'm using importData plugin
You either need to alter your dataset or do corrections after import.
I am not promising anything but maybe units can be imported as they are.
But we need your dataset and smath file for to check if it can be done.
WroteSuggestive ...
... Think in terms of sub-utilities you may need to apply.
Thanks for your replies, here are the files.
I would like to display variable z as kN/m instead of that kg/s^2
You're welcome
1 Pages (10 items)
![2023-06-12 10_26_44-SMath Solver - [Worksheet1.sm_].png](/zh-Hans-CN/files/Download/dkpT86/2023-06-12-10_26_44-SMath-Solver---[Worksheet1.sm_].png)
