The problem with the function of the vector
The problem with the function of the vector - Messages
#1 Posted: 2020/4/7 11:49:26
Andrey007
Andrey007
0 likes in 7 posts.
Please help with the prZadanie 2.sm (9.86 KiB) downloaded 1260 time(s).oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#2 Posted: 2020/4/7 16:16:24
Andrey007
Andrey007
0 likes in 7 posts.
File not found.
Please help with the prFile not found.oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#3 Posted: 2020/4/7 16:19:22
Andrey007
Andrey007
0 likes in 7 posts.
#4 Posted: 2020/4/7 19:47:33
1,443 likes in 2,935 posts.
Hello [userlink]Andrey007[/userlink]
Here there is your code adaped to SS syntax.
To loop the (scalar) functions through the values of a vector (1-column matrix) you can use vectorize or a for/while function.
Since in A=0 Kg(A) is indeterminate (0/0) and Kn(a) is an infinity and you can't plot that I've started the range from the 2nd value within the original range.
Zadanie 2_1.sm (12.66 KiB) downloaded 1261 time(s).
#5 Posted: 2020/4/8 09:29:23
Sorry for some gross mistake ... deleted.
You can use Smath code floor/ceiling
Zadanie 2_1[floor].sm (15.05 KiB) downloaded 1065 time(s).
#6 Posted: 2020/4/8 17:48:42
Andrey007
Andrey007
0 likes in 7 posts.
Thanks for the help, be healthy!
