1 страниц (6 вхождений)
The problem with the function of the vector - Сообщения
Please help with the prZadanie 2.sm (9,86 КиБ) скачан 1435 раз(а).oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
Thanks for the help
Файл не найден.
WrotePlease help with the prФайл не найден.oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
Hello [userlink]Andrey007[/userlink]
Here there is your code adaped to SS syntax.
To loop the (scalar) functions through the values of a vector (1-column matrix) you can use vectorize or a for/while function.
Since in A=0 Kg(A) is indeterminate (0/0) and Kn(a) is an infinity and you can't plot that I've started the range from the 2nd value within the original range.
Zadanie 2_1.sm (12,66 КиБ) скачан 1431 раз(а).
Sorry for some gross mistake ... deleted.
You can use Smath code floor/ceiling
Zadanie 2_1[floor].sm (15,05 КиБ) скачан 1238 раз(а).
