1 Pages (3 items)
Working Random Var [Compendium] - Working Random Var [Compendium] - Messages
Enrich your projects with this starter.
Random Signum.sm (17.88 KiB) downloaded 839 time(s).
Random Stem Style.sm (15.54 KiB) downloaded 821 time(s).
Random more.sm (22.5 KiB) downloaded 850 time(s).
Randon Bin [Stem].sm (20.15 KiB) downloaded 694 time(s).
Randon Bin.sm (58.31 KiB) downloaded 799 time(s).
Randon Segment Circular Shapes.sm (38.25 KiB) downloaded 832 time(s).
Random UnitCircle.sm (40.22 KiB) downloaded 823 time(s).
Random [rnd(n)].sm (55.55 KiB) downloaded 710 time(s).
Random Fill Range PDF.sm (991.43 KiB) downloaded 861 time(s).
Very nice examples Jean, as usual
The last file (where you presented the "fill" matrix - a large matrix in the gray area to the right) is an example where it might get you troubled. You can get red crossed box with Critical error, or at least the message "Object not set to an instance of an object". I think that you also mentioned this in some other examples. Presenting large matrices might be quite troublesome in SMath (although there are some plugins regarding this problem).
WrotePresenting large matrices might be quite troublesome in SMath
Radovan.
_______________________
That is true sometimes for unknown reason. And the worst is that it might work during
contruction, but zap on re-opening ! Other times it fails transmission. The "while"
looks solid in that respect. I tried many times 2000 points ... fine.
I'm used to these kind of problem from Mathcad. Sometimes the project is scrapped for
ever. We did the "Courant Surge" project for ITER [Cadarache], one of the data table
got lot and I have no more contact. It was not really a table, rather data:=
apparently less risky but evaporated. Crappy stuff gets transmitted as well.
Keep working hard 2016.
1 Pages (3 items)
