Working Random Var [Compendium]
Working Random Var [Compendium] - Working Random Var [Compendium] - Сообщения
#1 Опубликовано: 01.01.2016 11:23:24
Enrich your projects with this starter.
Random Signum.sm (17,88 КиБ) скачан 1572 раз(а).
Random Stem Style.sm (15,54 КиБ) скачан 1516 раз(а).
Random more.sm (22,5 КиБ) скачан 1564 раз(а).
Randon Bin [Stem].sm (20,15 КиБ) скачан 1288 раз(а).
Randon Bin.sm (58,31 КиБ) скачан 1512 раз(а).
Randon Segment Circular Shapes.sm (38,25 КиБ) скачан 1579 раз(а).
Random UnitCircle.sm (40,22 КиБ) скачан 1509 раз(а).
Random [rnd(n)].sm (55,55 КиБ) скачан 1299 раз(а).
Random Fill Range PDF.sm (991,43 КиБ) скачан 1585 раз(а).
#2 Опубликовано: 01.01.2016 12:25:53
Very nice examples Jean, as usual
The last file (where you presented the "fill" matrix - a large matrix in the gray area to the right) is an example where it might get you troubled. You can get red crossed box with Critical error, or at least the message "Object not set to an instance of an object". I think that you also mentioned this in some other examples. Presenting large matrices might be quite troublesome in SMath (although there are some plugins regarding this problem).
#3 Опубликовано: 02.01.2016 00:30:35
Radovan.
_______________________
That is true sometimes for unknown reason. And the worst is that it might work during
contruction, but zap on re-opening ! Other times it fails transmission. The "while"
looks solid in that respect. I tried many times 2000 points ... fine.
I'm used to these kind of problem from Mathcad. Sometimes the project is scrapped for
ever. We did the "Courant Surge" project for ITER [Cadarache], one of the data table
got lot and I have no more contact. It was not really a table, rather data:=
apparently less risky but evaporated. Crappy stuff gets transmitted as well.
Keep working hard 2016.
