SMath Studio 0.98.5983 (19 May 2016)
SMath Studio 0.98.5983 (19 May 2016) - Messages
#1 Posted: 2016/5/19 19:01:31
2,315 likes in 3,949 posts.
SMath Studio 0.98.5983 available
Latest changes (against SMath Studio 0.98.5973)
  • SS-2346: Handling of text strings to paste into the worksheet improved;
  • Changing size of matrix inside the element of output matrix disabled in order to fix critical error happened in such cases;
  • Added ability to select answer of math expression with manually set unit;
  • SS-2318: Corrections made, see Preprocessing of symbolic data / functions' arguments for details;
  • Cloud: Scrolling to top on every key down issue fixed.
Download
6 users liked this post
Davide Carpi 2016/5/19 19:51:00, Вячеслав Мезенцев 2016/5/20 01:45:00, NDTM Amarasekera 2016/5/20 09:05:00, Mike Kaganski 2016/5/20 10:17:00, sergio 2016/5/21 15:25:00, Tinu_ 2016/5/22 03:33:00
#2 Posted: 2016/5/25 13:21:51
Igor Skarine
Igor Skarine
14 likes in 97 posts.
The attached sample doesn't work with the latest build 5983, but worked fine with all previous versions.
It indicates error x - not defined. Actually x is dummy, it was used as a place-holder for symbolic calculation.
cic3.sm (4.21 KiB) downloaded 972 time(s).
