SMath Studio 0.98.5983 (19 May 2016)
SMath Studio 0.98.5983 (19 May 2016) - Сообщения
#1 Опубликовано: 19.05.2016 19:01:31
Группа: Super Administrator
SMath Studio 0.98.5983 available
Latest changes (against SMath Studio 0.98.5973)
  • SS-2346: Handling of text strings to paste into the worksheet improved;
  • Changing size of matrix inside the element of output matrix disabled in order to fix critical error happened in such cases;
  • Added ability to select answer of math expression with manually set unit;
  • SS-2318: Corrections made, see Preprocessing of symbolic data / functions' arguments for details;
  • Cloud: Scrolling to top on every key down issue fixed.
Download
6 пользователям понравился этот пост
Davide Carpi 19.05.2016 19:51:00, Вячеслав Мезенцев 20.05.2016 01:45:00, NDTM Amarasekera 20.05.2016 09:05:00, Mike Kaganski 20.05.2016 10:17:00, sergio 21.05.2016 15:25:00, Tinu_ 22.05.2016 03:33:00
#2 Опубликовано: 25.05.2016 13:21:51
Igor Skarine
Igor Skarine
14 сообщений из 97 понравились пользователям.
The attached sample doesn't work with the latest build 5983, but worked fine with all previous versions.
It indicates error x - not defined. Actually x is dummy, it was used as a place-holder for symbolic calculation.
cic3.sm (4,21 КиБ) скачан 1735 раз(а).
