1 Pages (6 items)
SHOW EQUATION, NOT RESULT - Messages
WroteI have an If shown in the image below.
I would like that in addition to the result of the equation,
it would also be shown from which equation the result originated.
It is possible?
Maybe ... but document is missing ... Ah !
Leandro, for example like this:
Leandro.sm (7.13 KiB) downloaded 1029 time(s).
As Jean says help us get help and always attach the smath file with the problematic example.
WroteLeandro, for example like this:
Thank´s so much Sergio. It´s Works very nice.
Next time I will put smath file.
Attach the math file only to check my solution. But this is in Portuguese!
Memoria de Calculo Monovia.sm (243.67 KiB) downloaded 995 time(s).
Often, if/otherwise is more convenient in program.
In some applications, program accepts only if/else.
Generally < is incompletely determined ... ≤ is completely determined.
It may result in an error message or simply an error w/o message.
if-else ... if-otherwise.sm (21.1 KiB) downloaded 1000 time(s).
1 Pages (6 items)
