SMath crashes on Linux Mint 22
SMath crashes on Linux Mint 22 - Messages
#1 Posted: 2024/8/20 23:51:26
Eugenio Fernández Carrasco
0 likes in 3 posts.
Hi all,
I have been using SMath Studio for several months, running as an AppImage on Linux Mint 21, without any problems. Recently, I upgraded to Linux Mint 22 and SMath Studio crashes when running. All errors are the following:
Quote
eugenio@TARDIS:~ $ ./SMathStudioDesktop.1_1_8763.Mono.x86_64.ubuntu-22_04.glibc2.35.AppImage
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000d4] in <728fbd68fe594062895e1f819791e76a>:0
--- End of inner exception stack trace ---
at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_generic_class_init(intptr)
at System.Drawing.Graphics.FromHdcInternal (System.IntPtr hdc) [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Windows.Forms.XplatUIX11.SetDisplay (System.IntPtr display_handle) [0x0007e] in :0
at System.Windows.Forms.XplatUIX11..ctor () [0x00077] in :0
at System.Windows.Forms.XplatUIX11.GetInstance () [0x0001c] in :0
at System.Windows.Forms.XplatUI..cctor () [0x000e3] in :0
at System.Windows.Forms.Application.EnableVisualStyles () [0x00006] in :0
at .. (System.String[] ) [0x0002d] in <868b174b35bf46d7860f868d305a3a08>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
Restoring environment...
Any idea how I can fix this? Thanks.
#2 Posted: 2024/8/21 01:52:29
598 likes in 1,380 posts.
Can you look if libgdiplus is installed?
Error messages are referring to that library.
#3 Posted: 2024/8/22 00:03:51
0 likes in 3 posts.
Yes it is installed on my system
#4 Posted: 2024/8/22 01:02:20
Can you look if mono package is working?
Maybe some libraries of new mint is not compatible with appimage.
https://smath.com/en-US/view/SMathStudio/download
#5 Posted: 2024/8/26 16:19:17
0 likes in 3 posts.
Mono version does not work. I think that some libraries are not compatible with this SMath version...
#6 Posted: 2024/8/26 17:28:14
Debian and debian based distros are always problematic with mono.
If you can make smath run with sudo, then there is a possible workaround.
Otherwise I'm sorry, it is debian (or ubuntu or mint)
