SMath crashes on Linux Mint 22
SMath crashes on Linux Mint 22 - Сообщения
#1 Опубликовано: 20.08.2024 23:51:26
Eugenio Fernández Carrasco
Hi all,
I have been using SMath Studio for several months, running as an AppImage on Linux Mint 21, without any problems. Recently, I upgraded to Linux Mint 22 and SMath Studio crashes when running. All errors are the following:
Цитата
eugenio@TARDIS:~ $ ./SMathStudioDesktop.1_1_8763.Mono.x86_64.ubuntu-22_04.glibc2.35.AppImage
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000d4] in <728fbd68fe594062895e1f819791e76a>:0
--- End of inner exception stack trace ---
at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_generic_class_init(intptr)
at System.Drawing.Graphics.FromHdcInternal (System.IntPtr hdc) [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Windows.Forms.XplatUIX11.SetDisplay (System.IntPtr display_handle) [0x0007e] in :0
at System.Windows.Forms.XplatUIX11..ctor () [0x00077] in :0
at System.Windows.Forms.XplatUIX11.GetInstance () [0x0001c] in :0
at System.Windows.Forms.XplatUI..cctor () [0x000e3] in :0
at System.Windows.Forms.Application.EnableVisualStyles () [0x00006] in :0
at .. (System.String[] ) [0x0002d] in <868b174b35bf46d7860f868d305a3a08>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
Restoring environment...
Any idea how I can fix this? Thanks.
#2 Опубликовано: 21.08.2024 01:52:29
593 сообщений из 1 370 понравились пользователям.
Can you look if libgdiplus is installed?
Error messages are referring to that library.
#3 Опубликовано: 22.08.2024 00:03:51
Yes it is installed on my system
#4 Опубликовано: 22.08.2024 01:02:20
Can you look if mono package is working?
Maybe some libraries of new mint is not compatible with appimage.
https://smath.com/en-US/view/SMathStudio/download
#5 Опубликовано: 26.08.2024 16:19:17
Mono version does not work. I think that some libraries are not compatible with this SMath version...
#6 Опубликовано: 26.08.2024 17:28:14
Debian and debian based distros are always problematic with mono.
If you can make smath run with sudo, then there is a possible workaround.
Otherwise I'm sorry, it is debian (or ubuntu or mint)
