import file ?
import file ? - Messages
#1 Posted: 2021/6/17 12:16:00
mnorena
mnorena
0 likes in 13 posts.
is it possible to import a file in txt to the smath and organize it by columns and rows???
#2 Posted: 2021/6/17 13:49:55
598 likes in 1,380 posts.
If you mean a comma separated file (csv), yes it is possible with importData().
#3 Posted: 2021/6/17 15:39:09
mnorena
mnorena
I allow your instrruccions, i dont know if i am doing ok, the name of the file is "ppp" and it shows me in the smath studio thats it is not reconized.
#4 Posted: 2021/6/17 15:49:26
If you could provide your file, it would be easier to check and input correct delimiters.
If you don't want to, just put a couple of lines. It can help to determine the function values.
#5 Posted: 2021/6/17 16:18:48
mnorena
mnorena
this it is the file, thanks for your help
ppp.txt (168.34 KiB) downloaded 960 time(s).
#6 Posted: 2021/6/17 16:27:20
You should write "ppp.txt" where you indicate your file.
You also just have to delete the first line from your data file.
It creates conflict between your function and data.
Data it provides don't match pattern of function.
So in result data can't be read.
Check below.
Show Spoiler
PS: martin is also right about getting partial data down below.
#7 Posted: 2021/6/17 17:12:18
1,355 likes in 2,271 posts.
You can access differently formatted sections by reading them separately.
import.sm (4.81 KiB) downloaded 1044 time(s).
