1 Pages (10 items)
Automatic numbering sections book - Messages
A template about how to create automatic numbering sections, figures, tables and equation labels.
Automatic numbering sections book.sm (84.05 KiB) downloaded 1477 time(s).
Razonar,
How do you start from paragraph 1? preferably 0?
Thanks,
Basile
PS. Can this be extended to have an automatic Table of Contents, List of Figures, List of Tables, and List of Equations?
Thanks,
Basile
WroteRazonar,
Thanks,
Basile
Hi Basile. You can start from any paragraph pointing the value of the variable '§, for example from paragraph six is: '§:mat(5,1,1)
For paragraph 1 use zero as starting value.
Yes, I it's possible automate the TOC, but I don't know how to catch in the SMath document the page number, so, I can do that but manually adding it. Index at the end of the attached.
Automatic numbering sections book.sm (85.25 KiB) downloaded 1160 time(s).
Вячеслав Мезенцев 2018/9/30 06:42:00
Very nice
I guess you can add the code in a function to reduce the code repetition and call only that function on the region placeholder
One day I'll resurrect the sections region project
WroteVery nice
I guess you can add the code in a function to reduce the code repetition and call only that function on the region placeholderOne day I'll resurrect the sections region project![]()
Yes, it's possible, let's me see if can do that.
Here, my old mcad 11 project for numbering pages.
numbers.zip (151.39 KiB) downloaded 359 time(s).
numbers.pdf (343.84 KiB) downloaded 926 time(s).
I never looked outside the document...
Any table of contents, figures, tables, equations, possible?
Thank you.
Basile
Thank you.
Basile
Hi. The One-Function version, with TOC at the end.
Automatic numbering sections book v2.sm (38.76 KiB) downloaded 1230 time(s).
Davide Carpi 2018/10/1 03:25:00
You can display the index at the begin of the document if you assign it to an absolute variable at the end (those variables starting with a tilde ~)
On german keyboards, the tilde has to be copied from a text region as it is catched as a hotkey for boolean = in math regions).
BTW, why don't you use formatted labels?
![2018-10-01 09_58_08-SMath Studio 0.99.6839 - [Automatic%20numbering%20sections%20book%20v3.sm].png](/zh-Hans-CN/files/Download/S7nvyG/2018-10-01-09_58_08-SMath-Studio-0.99.6839---[Automatic%20numbering%20sections%20book%20v3.sm].png)
Automatic%20numbering%20sections%20book%20v3.sm (40.27 KiB) downloaded 1453 time(s).
Hi Martin. Thanks for the update about global variables. I don't use formated labels because I want only to show how get automatic numbering into several SMath documents with native SMath tools. Without any doubt with formated labels it will looks great.
The formated label version.
Automatic numbering sections book - Formated label.sm (36.59 KiB) downloaded 1383 time(s).
5 users liked this post
Вячеслав Мезенцев 2018/10/1 21:10:00, frapuano 2018/10/2 06:05:00, sergio 2020/1/21 08:38:00, Igor K 2024/10/1 17:44:00, Thiago Pereira 2025/6/10 02:34:07
1 Pages (10 items)
