1 Pages (8 items)
Differentiation operator does not evaluate symbolically - Translate a differential operator from SMath to Maxima - Messages
Do you know why or what could be the problem for SMath not translating properly a dy/dx. I need to write these operators in Maxima to solve a differential equation...
Thanks in advance,
Differentiation.sm (9.34 KiB) downloaded 982 time(s).
Thanks in advance,
I have found a workaround, with eval_string() from Maxima.
Differentiation.sm (13.39 KiB) downloaded 981 time(s).
WroteHello,
Hola tocayo. Is this the problem?: always it is diff(y,x)=0, but diff(y(x),x) remains unevaluated and is the correct form to express the derivative of a function.
frapuano 2020/5/31 04:51:00
You are mixing two CAS that will not pass QA [Quality Assurance].
My understanding is that what was usable from Maxima is native in Smath.
Smath native derivative operator works from book library.
sin(x), ln(x), exp(x) ... OK
Gamma(x), erf(x) ... zap. We have them otherwise.
Differentiation.sm (17.82 KiB) downloaded 1000 time(s).
Thank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
WroteThank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
Very few DE have symbolic solutions, unless from Handbooks.
Few of them are available in Smath ... will be back on that.
WroteI am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
If Mathcad Prime does not solve those attached ... Oh !
ODE Symbolic 4_Flies.sm (130.62 KiB) downloaded 1014 time(s).
ODE Symbolic Bernoulli.sm (11.38 KiB) downloaded 1030 time(s).
ODE_Laplace 1rst [Type 2].sm (22.68 KiB) downloaded 799 time(s).
ODE Symbolic Verhulst [Logistic].sm (25.55 KiB) downloaded 863 time(s).
ODE Symbolic Lambert.sm (21.81 KiB) downloaded 1016 time(s).
ODE_Laplace 1rst [Type 1].sm (24.7 KiB) downloaded 821 time(s).
ODE_Laplace 2nd [Type 3].sm (34.62 KiB) downloaded 881 time(s).
ODE Symbolic Eiffel.sm (21.45 KiB) downloaded 977 time(s).
1 Pages (8 items)
