Standard templates?
Standard templates? - Is it possible to create (and re-use) a template in smath? - Messages
#1 Posted: 2020/8/3 13:51:52
Richyo
Richyo
0 likes in 2 posts.
Hi everyone, I’ve been using smath for about a year now (since mathcad became completely rubbish!) and use it for standard engineering calcs (mechanical and structural mainly).
I’m freelance so tend to perform calcs for many clients and have not yet found a way to create a standard calculation sheet template.
For example, whenever I start a new project I’d like a header or something on the front page to display my company name and a few other fields for title, project number, that sort of thing. Possibly even have a margin down one side for referencing standards or notes. Something like the sci calc sheets that are online would be great!
Does anyone know of a way to do this or is there a plug-in somewhere?
Any advice would be much appreciated.
Thanks!
Richard
#2 Posted: 2020/8/3 14:19:01
116 likes in 332 posts.
you can use:
Insert -> Header and Footer
Insert -> Field
Also you can see this post by Alvaro (Razonar)
https://en.smath.com/forum/yaf_postst13853_Automatic-numbering-sections-book.aspx
#3 Posted: 2020/8/3 14:29:06
Few ways of presenting professional works. Any use ?
Template.sm (15.57 KiB) downloaded 1178 time(s).
Template Background Multiple.sm (14.22 KiB) downloaded 1086 time(s).
Template Cartouche.sm (19.42 KiB) downloaded 986 time(s).
Template Background Construct.sm (47.88 KiB) downloaded 1072 time(s).
Template Cartouche Venturi.sm (21.78 KiB) downloaded 946 time(s).
Template Else Source.sm (3.94 KiB) downloaded 973 time(s).
Template Cartouche CREATE.sm (53.17 KiB) downloaded 906 time(s).
Template Cartouche Saved.sm (4.53 KiB) downloaded 911 time(s).
Template Guy.sm (2.65 KiB) downloaded 997 time(s).
Template Cartouche Example.sm (34.49 KiB) downloaded 943 time(s).
Template YellowCorn.sm (3.31 KiB) downloaded 963 time(s).
Template Cartouche Geoff.sm (31.7 KiB) downloaded 909 time(s).
Template Cartouche Otherwise.sm (74.54 KiB) downloaded 938 time(s).
#4 Posted: 2020/9/2 09:48:17
Richyo
Richyo
0 likes in 2 posts.
Hi, apologies for the delayed response! The templates linked below are great - thank you for providing these.
I've looked at a few and haven't quite found what I need yet but I'll work on it. Once I have something I'll post it here so everyone else can use it (if they want to!)
Thanks again,
Richard
#5 Posted: 2020/9/2 13:15:51
Visit them all for the next month !
Foot note standard/references best go in collapsed above document.
#6 Posted: 2022/1/5 15:08:29
Claudio Andre
Claudio Andre
0 likes in 3 posts.
Create an empty file with your template settings and set it as readonly, when you try to save Smath will ask you a new name.
