Standard templates?
Standard templates? - Is it possible to create (and re-use) a template in smath? - Сообщения
#1 Опубликовано: 03.08.2020 13:51:52
Richyo
Richyo
Hi everyone, I’ve been using smath for about a year now (since mathcad became completely rubbish!) and use it for standard engineering calcs (mechanical and structural mainly).
I’m freelance so tend to perform calcs for many clients and have not yet found a way to create a standard calculation sheet template.
For example, whenever I start a new project I’d like a header or something on the front page to display my company name and a few other fields for title, project number, that sort of thing. Possibly even have a margin down one side for referencing standards or notes. Something like the sci calc sheets that are online would be great!
Does anyone know of a way to do this or is there a plug-in somewhere?
Any advice would be much appreciated.
Thanks!
Richard
#2 Опубликовано: 03.08.2020 14:19:01
you can use:
Insert -> Header and Footer
Insert -> Field
Also you can see this post by Alvaro (Razonar)
https://en.smath.com/forum/yaf_postst13853_Automatic-numbering-sections-book.aspx
#3 Опубликовано: 03.08.2020 14:29:06
Few ways of presenting professional works. Any use ?
Template.sm (15,57 КиБ) скачан 1868 раз(а).
Template Background Multiple.sm (14,22 КиБ) скачан 1776 раз(а).
Template Cartouche.sm (19,42 КиБ) скачан 1700 раз(а).
Template Background Construct.sm (47,88 КиБ) скачан 1765 раз(а).
Template Cartouche Venturi.sm (21,78 КиБ) скачан 1641 раз(а).
Template Else Source.sm (3,94 КиБ) скачан 1683 раз(а).
Template Cartouche CREATE.sm (53,17 КиБ) скачан 1616 раз(а).
Template Cartouche Saved.sm (4,53 КиБ) скачан 1593 раз(а).
Template Guy.sm (2,65 КиБ) скачан 1696 раз(а).
Template Cartouche Example.sm (34,49 КиБ) скачан 1615 раз(а).
Template YellowCorn.sm (3,31 КиБ) скачан 1646 раз(а).
Template Cartouche Geoff.sm (31,7 КиБ) скачан 1611 раз(а).
Template Cartouche Otherwise.sm (74,54 КиБ) скачан 1631 раз(а).
#4 Опубликовано: 02.09.2020 09:48:17
Richyo
Richyo
Hi, apologies for the delayed response! The templates linked below are great - thank you for providing these.
I've looked at a few and haven't quite found what I need yet but I'll work on it. Once I have something I'll post it here so everyone else can use it (if they want to!)
Thanks again,
Richard
#5 Опубликовано: 02.09.2020 13:15:51
Visit them all for the next month !
Foot note standard/references best go in collapsed above document.
#6 Опубликовано: 05.01.2022 15:08:29
Claudio Andre
Claudio Andre
Create an empty file with your template settings and set it as readonly, when you try to save Smath will ask you a new name.
