Pulses and Waveforms
Pulses and Waveforms - MCad - SMath Studio - Messages
#1 Posted: 2021/4/16 17:32:09
Norm Schutzkus
Norm Schutzkus
9 likes in 90 posts.
Hello SMATH Forum,
I recently came across a set of MathCad sheets, which I am attempting to extract a small sample; rectified waveform and ripple. As I am trying to reconstruct in SMath, early on, I cannot resolve a few definitions; functions "rect1(...)" and "g1hw(...).
I'm hoping someone can help. Attached is my SMath sheet and the reference MathCad15 files.
File not found.File not found.File not found.
I welcome your review and look forward to your reply.
Sincerely,
Norm
#2 Posted: 2021/4/16 18:36:17
The *.sm document does not open ... PDF YES
Play with these two ... Jean
Page5 Norm.sm (20.55 KiB) downloaded 1168 time(s).
#3 Posted: 2021/4/16 21:00:31
... added numerical convolution.
From brushing the *.PDF "pulse" has no limit.
Show some you need for concluding a project.
Page5 Norm.sm (26.84 KiB) downloaded 1114 time(s).
#4 Posted: 2021/4/16 22:07:11
Norm Schutzkus
Norm Schutzkus
Pulses and Waveforms work in progress.sm (679.02 KiB) downloaded 1078 time(s).
Thanks Jean! I hope the attached works now.
The function g1hw fails. The comment "k - not defined". Hopefully, the attached pdf of my fist page give you an idea. Pulses and Waveforms work in progress - nas.pdf (129.72 KiB) downloaded 637 time(s).
Best regards,
Norm
#5 Posted: 2021/4/16 22:42:57
1,123 likes in 1,795 posts.
Hi Norm. Some few notes:
- For speed up the code, you must to put at some places some eval() in SMath.
- Some vectorization are automatics in Mathcad, but not in SMath. Here you can use the index nk instead implicit or explicit vectorization, as shows the picture.
- N0.gc is 2^8, and it is for use as the finite index for fast Fourier sums, but it's too big for SMath. Use something lower.
- T.hw is undefined in you worksheet.
#6 Posted: 2021/4/17 09:39:55
Your latest version opens, but SS 6179 complains, can't make it work.
Can you reproduce as doctored by Alvaro, to see something.
Experiment the Pulse Train ... it does a lot !
#7 Posted: 2021/4/17 17:57:22
Norm Schutzkus
Norm Schutzkus
Many thanks Alvaro & Jean,
As always, I appreciate your high-level knowledge using this fantastic tool!
Stay safe and take care.
Sincerely,
Norm
#8 Posted: 2021/6/1 19:39:35
Norm Schutzkus
Norm Schutzkus
Work in progress...
I gave up on the MathCad "Pulses and Waveforms" conversion.
The attached sheet is not complete, just my attempts at the graphs thus-far. I'll need to spend some time working in the diodes conduction range.
Anyway, using the discharge profile looks close, not correct, but has a close resemblance.
Best regards,
Norm
Single-phase full-wave bridge rectifier circuit with C-filter and resistive load.sm (338.44 KiB) downloaded 1108 time(s).
#9 Posted: 2021/6/2 13:06:59
This one is above my head.
On the other hand, Smath depends largely upon "plugins"
and they don't behave all same, i.e: Fourier stuff.
In the mean time, you can visit these 4 examples.
Convolution RC 6179.sm (13.87 KiB) downloaded 1014 time(s).
Convolution Numerical [Pulse model].sm (26.48 KiB) downloaded 828 time(s).
Convolution Pulse Integration.sm (31.68 KiB) downloaded 999 time(s).
Laplace Admittance Analyzer.sm (1.03 MiB) downloaded 1114 time(s).
#10 Posted: 2021/6/2 18:55:11
This one is very useful as you mesh and range from the creation..
Superb to highlight segments.
#11 Posted: 2021/6/2 19:53:24
Norm Schutzkus
Norm Schutzkus
Thanks Jean! I'll look at this.
Best regards,
Norm
