Howto evaluate this sum function to define a matrix?
Howto evaluate this sum function to define a matrix? - Messages
#1 Posted: 2015/11/16 13:34:03
archbuilder
archbuilder
0 likes in 4 posts.
Hello smath-forum,
I am trying to use the equations below to define a matrix.
The result should be a 3x3 matrix per equation. Which later is composed to a 6x6 matrix:
AB
BD
Is that possible in smath? If yes - how could it be done?
equations
Q is 3x3 matrix
Q* is 2x2 matrix
Is something like this allready documented or should i do it?
in hope for your support
redet
#2 Posted: 2015/11/17 20:50:10
1,443 likes in 2,935 posts.
You have to define A,B,D in a loop, then you can merge the matrices using augment(...) and stack(...)
#3 Posted: 2015/11/18 05:25:23
archbuilder
archbuilder
0 likes in 4 posts.
Thank you this works very good.
An alternative is to write the equations into a Matrix and that loop over it:
alternative path
