Animate plots
Animate plots - Messages
#1 Posted: 2019/11/6 06:41:56
hanskl
hanskl
7 likes in 158 posts.
Hi guys.
Seeing how fast I got great and helpful answers yesterday, I thought I might ask another rather silly question. I am trying to animate a plot, and I have never done it before.
I have made a simple sheet ploting V,M for a rectangular simply supported beam with uniformly distributed load. I have also plotted sigma and tau for the section, as well as Von Mises.
I have tried to make 3D plots to show how stresses evovle through the length of the beam, and to some extent it illustrates that.
I have also tried to animate a 2D plot, to work like a cross section that moves along the length of the beam, but I cannot figure out how to make it work.
Any ideas where it went wrong for me?
Also; is it possible to plot stresses along y-axis as opposed to x-axis?
Thanks again :d
spenninger bjelke.sm (30.46 KiB) downloaded 1056 time(s).
#2 Posted: 2019/11/6 11:11:51
Oh !!! too many questions in there.
Some typical animations:
0Anim Brownian.sm (9.94 KiB) downloaded 995 time(s).
0Anim Butterfly.sm (15.42 KiB) downloaded 1034 time(s).
0Anim Analemma.sm (29.27 KiB) downloaded 1026 time(s).
0Anim Brownian 3D [Ber7].sm (24.55 KiB) downloaded 795 time(s).
0Anim CONVOLUTION.sm (27.89 KiB) downloaded 982 time(s).
0Anim Cheval.sm (21.64 KiB) downloaded 1013 time(s).
0Anim Lorenz Attractor.sm (6.08 KiB) downloaded 1087 time(s).
0Anim Ellipse.sm (13.85 KiB) downloaded 999 time(s).
0Anim Lorenz Attractor Norm2r.sm (10.48 KiB) downloaded 1029 time(s).
0Anim Gozilla.sm (11.57 KiB) downloaded 1014 time(s).
0Anim Model [Lissajous, Brownian, Butterfly].sm (39.48 KiB) downloaded 851 time(s).
0Anim Trifolium [Windmill Ber7].sm (25.85 KiB) downloaded 853 time(s).
0Anim Trifolium [Windmill].sm (17.34 KiB) downloaded 824 time(s).
#3 Posted: 2019/11/6 12:31:32
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Check out this thread
https://en.smath.com/forum/yaf_postst1068_Beam-calculation.aspx
#4 Posted: 2019/11/6 12:51:59
1. Yes as discrete format ... augment(y,x) in reverse order.
2. surface 3D does not save settings. Plot f,g,j
not you had plot f(x,y) ...
3. can't doctor the last plot ... proved otherwise.
spenninger bjelke _1.sm (55.57 KiB) downloaded 1033 time(s).
#5 Posted: 2019/11/6 17:45:06
hanskl
hanskl
Wowzers!
#6 Posted: 2019/11/6 17:47:42
hanskl
hanskl
Thanks Jean!
I will try to plot about y-axis with the augment function.
Surface 3D not saving settings explains a lot! I think I tried to save those settings at least 10 times before giving up.
I will try to understand how plot animations work, and come back with a animated plot of my stresses..
Best regards,
Hans Kristian.
#7 Posted: 2019/11/6 18:58:23
hanskl
hanskl
Well, I got the animations to work. I guess the mistake was to try to animate on a variable named 't'.
With a bit more tinkering I should be able to plot my stresses about y-y axis as well.
Best regards,
Hans Kristian
spenninger bjelke.sm (32.03 KiB) downloaded 1067 time(s).
#8 Posted: 2019/11/6 21:25:26
I saved it under your name [Project Hans].
Always credit what's not personal.
#9 Posted: 2019/11/7 00:31:04
... that one is for training your Olympic Monkey !
First: show him the Smath video ... enjoy.
0Anim Fourier MonkeyBranching.sm (14.48 KiB) downloaded 1050 time(s).
#10 Posted: 2019/11/7 06:06:33
hanskl
hanskl
I find it somewhat funny my simple stress visualization sheet was something you deemed worthy of saving on your harddrive.
Thanks,
Hans Kristian
#11 Posted: 2019/11/7 18:07:53
It carries units so nicely, not usual vs so many projects
that fail [Units don't match].
The attach breakfast with chicken rather than eggs.
At least, my small laptop does not smoke.
Pattern Julia Set [PUBLISH].sm (25.09 KiB) downloaded 816 time(s).
#12 Posted: 2019/11/8 07:08:47
hanskl
hanskl
Thank you!
Mine actually managed this sheet in 1.2 minutes.. :d
#13 Posted: 2019/11/8 13:31:53
Fridel Selitsky
Fridel Selitsky
Another variation of Jean animation
0Anim Fourier MonkeyBranching 1.sm (18.08 KiB) downloaded 1046 time(s).
#14 Posted: 2019/11/8 14:58:53
2,340 likes in 4,041 posts.
0.8 min using latest 7251:
Significant (20x) performance improvement for 3 years.
#15 Posted: 2019/11/8 21:42:22
Impressive improvement ... MCD 11 XP Pro [4 sec]
Thanks Andrey ... Jean
