Simpson Recursive Adaptive
Simpson Recursive Adaptive - Simpson Recursive Adaptive Integral Method - Messages
#1 Posted: 2019/10/8 17:58:48
CBG
CBG
78 likes in 312 posts.
Hello
Here is an example of integration using the Simpson recursive adaptive method.
Adaptive_Recursive_Simpson_SS6179.sm (13.29 KiB) downloaded 1157 time(s).
On the other hand, when running the algorithm in the versions of Smath Studio 6179 and 7219,
I realize that the SS-6179 version is more accurate than the current SS-7219, since the
first one allows an error of 0.000000001, while the latter only allows an error of 0.000001
Adaptive_Recursive_Simpson_SS7219.sm (14.55 KiB) downloaded 1120 time(s).
The SS-7219 version cannot calculate the function with an error of less than 0.000001 to achieve greater accuracy.
Are we going back?
Carlos
frapuano 2019/10/8 23:51:00
#2 Posted: 2019/10/8 22:24:13
My native SS 6179 supports ε:=0.0000000000001
@ equivalent accuracy, Romberg-Simpson kernel runs ~ 8 times faster.
Most puzzling from version to version
On my slow laptop:
Romberg-Simpson ..... 12 s
Simpson recursive ... 96 s
Simpson kernel in Romberg range [0..1] at decimation [n]
is most valuable on large range of the integration variate 'x'.
Thanks Carlos, most interesting ... Jean.
Integrate Companion [Technical Accuracy Carlos Recursive].sm (29.14 KiB) downloaded 960 time(s).
#3 Posted: 2019/10/9 03:58:08
Strange thing happened to my Win7 machine (SMath 7219) and both files (by Carlos and Jean).
Running both files will just close SMath without any warning.
See this animated gif please.
This does not happen to my Win10 machine.
#4 Posted: 2019/10/9 04:33:09
127 likes in 342 posts.
On my machine win 7 (PRO 64bit) does not experience the problem of Radovan. Instead, I confirm the problem with the minimum precision value assigned
#5 Posted: 2019/10/9 11:03:38
What about separate each integrator and run 7219 ?
I guess you have tried. So, your Win 7 is kookoo.
#6 Posted: 2019/10/9 11:35:47
Hello Jean,
Int() is going well but AdapRecursive() makes SMath to shut down when decreasing epsilon on my "kookoo" Win7
#7 Posted: 2019/10/9 13:11:09
Conclusion: Recursive code complains foo low epsilon.
But, that's what Carlos observed, isn't it ?
You may have to first define Recursive as a wild algo,
then insert parameters.
#8 Posted: 2019/10/11 20:24:36
... download the MASTER Toolbox, updated a minute ago.
All my projects are based on those utilities.
Competitive with Mathcad/Mathsoft, Wolfram Alpha.
Here is ...
Integral 00000000 MASTER ToolBox Copy.sm (477.06 KiB) downloaded 1179 time(s).
