Animation Compendium
Animation Compendium - Animation Compendium - Messages
#1 Posted: 2016/8/21 21:05:22
Animation adds live to projects.
Enjoy your vist.
0Anim Brownian.sm (8.86 KiB) downloaded 1348 time(s).
0Anim Analemma.sm (28.67 KiB) downloaded 1252 time(s).
0Anim Ellipse.sm (13.42 KiB) downloaded 1278 time(s).
0Anim Cheval.sm (21.13 KiB) downloaded 1310 time(s).
0Anim Gozilla.sm (11.26 KiB) downloaded 1254 time(s).
0Anim XFR.sm (11.65 KiB) downloaded 1296 time(s).
Davide Carpi 2016/8/22 12:05:00
#2 Posted: 2016/8/21 22:13:52
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Hi Jean
The program will run faster if the code is a little change
0Anim XFR1.sm (13.23 KiB) downloaded 1262 time(s).
Davide Carpi 2016/8/22 12:04:00
#3 Posted: 2016/8/22 00:56:24
Thanks Ber7 for the code.
On that one "0Anim CONVOLUTION" ... can't accumulate the path ?
Cheers, Jean
0Anim CONVOLUTION.sm (18.42 KiB) downloaded 1289 time(s).
#4 Posted: 2016/8/22 03:57:54
Fridel Selitsky
Fridel Selitsky
Instead tmin = 0 substitute the tmin=1
0Anim XFR1.sm (13.23 KiB) downloaded 1307 time(s).
#5 Posted: 2016/8/22 08:52:26
0Anim CONVOLUTION .sm
has been doctored for the accumulated path.
Plots are difficult to size, work sheet is Autocal OFF
0Anim CONVOLUTION.sm (30.72 KiB) downloaded 1327 time(s).
#6 Posted: 2016/8/22 12:35:58
2,340 likes in 4,041 posts.
Thank you for interesting examples!
I've checked your worksheets and see one place for simple optimization applicable for most of them.
Often you use procedures to draw static set of points for all frames of animation. Procedures (when line is used right after the definition operator) calculated on every call - SMath Studio do not precalculate their values.
So, you can speed up calculation simply by line like this:
This line asks the program to calculate procedure and store its values into the initial procedure variable. So, we have only one calculation of static shape for the whole animation!
I've corrected your examples according to the hint above and tested them in both versions: 0.97.5346 - the one you have used to create files and 0.98.6077 - the latest nightly build. Here are the results:
Final versions of the worksheets:
Fridel Selitsky 2016/8/22 12:43:00, frapuano 2016/8/22 15:11:00, Davide Carpi 2016/8/23 04:25:00
#7 Posted: 2016/8/22 21:39:48
Thanks Andrey: I toke good note and adapted.
