Animation Compendium
Animation Compendium - Animation Compendium - Сообщения
#1 Опубликовано: 21.08.2016 21:05:22
Animation adds live to projects.
Enjoy your vist.
0Anim Brownian.sm (8,86 КиБ) скачан 1553 раз(а).
0Anim Analemma.sm (28,67 КиБ) скачан 1434 раз(а).
0Anim Ellipse.sm (13,42 КиБ) скачан 1474 раз(а).
0Anim Cheval.sm (21,13 КиБ) скачан 1508 раз(а).
0Anim Gozilla.sm (11,26 КиБ) скачан 1448 раз(а).
0Anim XFR.sm (11,65 КиБ) скачан 1488 раз(а).
Davide Carpi 22.08.2016 12:05:00
#2 Опубликовано: 21.08.2016 22:13:52
Fridel Selitsky
Fridel Selitsky
Hi Jean
The program will run faster if the code is a little change
0Anim XFR1.sm (13,23 КиБ) скачан 1440 раз(а).
Davide Carpi 22.08.2016 12:04:00
#3 Опубликовано: 22.08.2016 00:56:24
Thanks Ber7 for the code.
On that one "0Anim CONVOLUTION" ... can't accumulate the path ?
Cheers, Jean
0Anim CONVOLUTION.sm (18,42 КиБ) скачан 1472 раз(а).
#4 Опубликовано: 22.08.2016 03:57:54
Fridel Selitsky
Fridel Selitsky
Instead tmin = 0 substitute the tmin=1
0Anim XFR1.sm (13,23 КиБ) скачан 1487 раз(а).
#5 Опубликовано: 22.08.2016 08:52:26
0Anim CONVOLUTION .sm
has been doctored for the accumulated path.
Plots are difficult to size, work sheet is Autocal OFF
0Anim CONVOLUTION.sm (30,72 КиБ) скачан 1514 раз(а).
#6 Опубликовано: 22.08.2016 12:35:58
Группа: Super Administrator
Thank you for interesting examples!
I've checked your worksheets and see one place for simple optimization applicable for most of them.
Often you use procedures to draw static set of points for all frames of animation. Procedures (when line is used right after the definition operator) calculated on every call - SMath Studio do not precalculate their values.
So, you can speed up calculation simply by line like this:
This line asks the program to calculate procedure and store its values into the initial procedure variable. So, we have only one calculation of static shape for the whole animation!
I've corrected your examples according to the hint above and tested them in both versions: 0.97.5346 - the one you have used to create files and 0.98.6077 - the latest nightly build. Here are the results:
Final versions of the worksheets:
Fridel Selitsky 22.08.2016 12:43:00, frapuano 22.08.2016 15:11:00, Davide Carpi 23.08.2016 04:25:00
#7 Опубликовано: 22.08.2016 21:39:48
Thanks Andrey: I toke good note and adapted.
