[Writer Region] Print Preview Delay in 98.6179
[Writer Region] Print Preview Delay in 98.6179 - Messages
#1 Posted: 2017/1/10 10:54:30
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
In 98.6179, it takes a long time for Print Preview to complete a document with several pages.
It happens with all my SS files.
Has anybody tried?
#2 Posted: 2017/1/10 18:12:17
Has anybody tried?
Win 7, 1.6 GHz Laptop
4 pages Smath that calculates in 30 sec
opens Preview in ~ 2 sec or less.
#3 Posted: 2017/1/10 22:21:51
... try that one:
it opens the preview on the click [so to speak].
Spline Quadratic Holistic.sm (67.77 KiB) downloaded 1101 time(s).
#4 Posted: 2017/1/11 10:47:12
NDTM Amarasekera
NDTM Amarasekera
Hi Jean,
Thank you very much for your prompt response.
I use Win 10 64 bit version.
No problems with Print Previews in Excel, Word etc.
The delay occurs only with SS 98.6179. A 7 page file takes about 2 minutes, while it was not so in earlier versions.
Any clues?
#5 Posted: 2017/1/11 11:45:58
1,443 likes in 2,935 posts.
I can load 11 pages almost instantly
You might try these:
  1. Try to change the default printer (print > Select printer > right click on another printer > set as default printer > close the window > try run again print preview)
  2. Try with a portable version
#6 Posted: 2017/1/11 12:41:07
Alexander O. Melnik
Alexander O. Melnik
127 likes in 498 posts.
Hi Jean,
Any clues?
Can you post a particular page as an example
#7 Posted: 2017/1/11 23:03:11
NDTM Amarasekera
NDTM Amarasekera
  • Try to change the default printer (print
  • At the moment I don't have a printer, so I selected a PDF printer.
    But still the problem exists. It was no so with earlier versions.
    As requested by Alex, sample file is attached.
    Reservoir Flood Capacity Estimation-R1.sm (207.06 KiB) downloaded 1105 time(s).
    #8 Posted: 2017/1/11 23:46:22
    Oh ! 2 minutes: that is a damned bug.
    It takes about ½ sec per page in my "steam engine" win 7 [6179].
    Do you have many uncompressed images ?
    #9 Posted: 2017/1/12 02:10:54
    NDTM Amarasekera
    NDTM Amarasekera
    The delay occurs even without images.
    My laptop is Asus i5-5200U CPU-@2.20 GHz with 6.0 GB RAM.
    I tried several attempts in configuring print options but no success.
    May be I have to try a fresh installation of SS 6179.
    Thanks.
    #10 Posted: 2017/1/12 06:40:43
    Stepan
    Stepan
    0 likes in 3 posts.
    Hello, there is one more detail to this subject - when you press the Print button on the toolbar of the Print window does not appear active and you have to click twice to start printing or to perform other actions in this window.
    #11 Posted: 2017/1/12 08:21:06
    Thank you NDTM,
    with your file I'm able to reproduce the issue; I think it might be related to recent changes of WriterRegion to make the regions display faster on the worksheet (proof: disable the plug-in, close and reopen SS, skip warnings, try again the print preview). I'll check if I can do something.
    I'm not able to reproduce, anyone else experience this issue?
    #12 Posted: 2017/1/12 11:26:16
    Please try in the Extensions Manager the latest beta of Writer Region
    #13 Posted: 2017/1/12 11:29:45
    NDTM Amarasekera
    NDTM Amarasekera
    Thank you NDTM,
    Thank you Davide!
    As suggested by you, Print Preview worked almost instantly without the "WriterRegion" plugin.
    Since the introduction of this plugin, I have used it extensively in almost all my SS files.
    That is the region why I had the problem with those files.
    Thank you again Davide.
    I am confident that you will resolve it ASAP.
    #14 Posted: 2017/1/12 11:44:40
    NDTM Amarasekera
    NDTM Amarasekera
    This this works fine. Thank you!
    But there is a problem with "Text Region Utilities" plugin to install.
    Davide Carpi 2017/1/12 12:17:00
    #15 Posted: 2017/1/12 12:05:46
    NDTM Amarasekera
    NDTM Amarasekera
    Thank you Davide.
    The update for "Text Region Utilities" is OK now.
    #16 Posted: 2017/1/12 12:07:13
    You're welcome, thank you for reporting this issue
    Thanks again; updated both the plugins (added another small performance improvement for print preview).
