design decision
design decision - comparing results - Messages
#1 Posted: 2015/12/15 22:33:44
studoc
studoc
0 likes in 17 posts.
Looking for a little guidance..
I'm an engineer, and use Smath in structural design.
In doing so I often need to compare a calculated capacity to a design load.
Can anyone suggest an elegant method of reporting a "result", being: pass or: fail……?
thanks,
Stu.
#2 Posted: 2015/12/16 01:36:16
Ernesto
Ernesto
13 likes in 74 posts.
One way is to use the conditionally formatted labels extension.
http://en.smath.info/forum/yaf_postst2100_Conditionally-Formatted-Labels.aspx
Another is to present your results in table form using the table region.
http://en.smath.info/forum/yaf_postst1953_Table-Region.aspx
studoc 2015/12/16 02:54:00, Davide Carpi 2015/12/16 11:53:00
#3 Posted: 2015/12/16 09:57:53
csb531
csb531
0 likes in 24 posts.
I use most of the time a very simple "if" condition.
No need for plug-ins and very easy to check for any reader.
By using indices you can also create a "table" with all "OK" an "FALSE" results. This can be convenient if you have different load cases with each one or more checks in a large document.
See the attached image.
Hope it is usefull for you!
Regards, csb.
#4 Posted: 2015/12/16 16:40:29
116 likes in 332 posts.
I am in agreement with CSB.
You can define a simple function to be used as needed
[albumimg]1420[/albumimg]
#5 Posted: 2015/12/17 01:58:17
Interesting: that reminds me to instruct Smath about a "Truth table", like Mathcad.
#6 Posted: 2015/12/17 12:28:12
uncblue
uncblue
2 likes in 18 posts.
This is how I typically show my utilization/stress ratios.
