1 Pages (7 items)
calculation in table - Messages
Is possible to make calculation in table, like excel?
Not that I am aware off, but you can "connect" to EXCEL if you have it on your windows machine:
https://en.smath.info/forum/yaf_postst4375_Plugin---EXCEL--2003--I-O-with-recalculation-and-export-to-PNG.aspx
WroteIs possible to make calculation in table, like excel?
Your question is too vague, a bit of work sheet would help.
In short: there is no known limit about what Smath can do
within a matrix [its own matrix] wrt the project you are Engineering.
Then, you may send to Excel via Alex plugin.
Alex, please correct me if wrong !
Cheers.
Hi Paulius,
I had a similar problem.
I wanted to create a table of values for a project at work that could be easily read by non SMath people (i.e. I wanted a nice looking table but also array names with text to identify the value rather than numbers)
Some of the values were fixed (sizes , powers or text ) but I needed to perform calculations on some of the values and incorporate it in a table.
I came up with the following method using TableRegions , although it looks a little complicated it works great and generates a great looking table and I can use arrays with meaning full text identifiers.
The attached file is annotated so should be fairly self explainatory and there are some examples of how to use the values at the bottom.
If you have a problems with it let me know.
TableRegion example by PJF.sm (30.69 KiB) downloaded 1331 time(s).
Peter
Peter
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
Thanks Peter: gorgeous ! mm² ... mm[Alt+253]
Hi Paulis ... here is some bed time reading
Rotate Eol.sm (28.47 KiB) downloaded 1193 time(s).
Utilities Matrix Truth Table.sm (59.2 KiB) downloaded 1129 time(s).
0Anim Brownian.sm (9.94 KiB) downloaded 1101 time(s).
2D Fill Stem.sm (12.71 KiB) downloaded 1111 time(s).
0Anim Ellipse.sm (13.85 KiB) downloaded 1115 time(s).
0Anim Analemma.sm (29.24 KiB) downloaded 1135 time(s).
Inst_Colebrook Pipe Data.sm (60.09 KiB) downloaded 1163 time(s).
2D Isometric Copy.sm (77.29 KiB) downloaded 1066 time(s).
Utilities Matrix Treasury Copy.sm (355.68 KiB) downloaded 1104 time(s).
Rotate Image RGB.sm (348.52 KiB) downloaded 1132 time(s).
Rotate Breather [4 Orientations].sm (1000.05 KiB) downloaded 936 time(s).
Image ZOOM Cosmos RGB.sm (1.79 MiB) downloaded 1112 time(s).
WroteWroteIs possible to make calculation in table, like excel?
Cheers.
Agree with Jean - you can do all sorts of operations in SMath with matricies and then present them as a table region OR you could use excel to do an present all the table stuff for you.
1 Pages (7 items)
