1 страниц (7 вхождений)
calculation in table - Сообщения
Is possible to make calculation in table, like excel?
Not that I am aware off, but you can "connect" to EXCEL if you have it on your windows machine:
https://en.smath.info/forum/yaf_postst4375_Plugin---EXCEL--2003--I-O-with-recalculation-and-export-to-PNG.aspx
WroteIs possible to make calculation in table, like excel?
Your question is too vague, a bit of work sheet would help.
In short: there is no known limit about what Smath can do
within a matrix [its own matrix] wrt the project you are Engineering.
Then, you may send to Excel via Alex plugin.
Alex, please correct me if wrong !
Cheers.
Hi Paulius,
I had a similar problem.
I wanted to create a table of values for a project at work that could be easily read by non SMath people (i.e. I wanted a nice looking table but also array names with text to identify the value rather than numbers)
Some of the values were fixed (sizes , powers or text ) but I needed to perform calculations on some of the values and incorporate it in a table.
I came up with the following method using TableRegions , although it looks a little complicated it works great and generates a great looking table and I can use arrays with meaning full text identifiers.
The attached file is annotated so should be fairly self explainatory and there are some examples of how to use the values at the bottom.
If you have a problems with it let me know.
TableRegion example by PJF.sm (30,69 КиБ) скачан 1507 раз(а).
Peter
Peter
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
Tnank You Peter
Thanks Peter: gorgeous ! mm² ... mm[Alt+253]
Hi Paulis ... here is some bed time reading
Rotate Eol.sm (28,47 КиБ) скачан 1387 раз(а).
Utilities Matrix Truth Table.sm (59,2 КиБ) скачан 1307 раз(а).
0Anim Brownian.sm (9,94 КиБ) скачан 1275 раз(а).
2D Fill Stem.sm (12,71 КиБ) скачан 1285 раз(а).
0Anim Ellipse.sm (13,85 КиБ) скачан 1286 раз(а).
0Anim Analemma.sm (29,24 КиБ) скачан 1314 раз(а).
Inst_Colebrook Pipe Data.sm (60,09 КиБ) скачан 1328 раз(а).
2D Isometric Copy.sm (77,29 КиБ) скачан 1228 раз(а).
Utilities Matrix Treasury Copy.sm (355,68 КиБ) скачан 1270 раз(а).
Rotate Image RGB.sm (348,52 КиБ) скачан 1317 раз(а).
Rotate Breather [4 Orientations].sm (1000,05 КиБ) скачан 1110 раз(а).
Image ZOOM Cosmos RGB.sm (1,79 МиБ) скачан 1300 раз(а).
WroteWroteIs possible to make calculation in table, like excel?
Cheers.
Agree with Jean - you can do all sorts of operations in SMath with matricies and then present them as a table region OR you could use excel to do an present all the table stuff for you.
