plotting circle does not work
plotting circle does not work - Help - Messages
#1 Posted: 2022/3/13 10:52:33
Blackbambi
Blackbambi
0 likes in 3 posts.
I am trying to plot mohr's circle by following tutorial. I have succeeded to draw circle on the tutorial but not mine.
Could you check my plot?
Thank you.MSS_Failure criterion.sm (8.47 KiB) downloaded 1142 time(s).
#2 Posted: 2022/3/13 11:47:06
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
One way to build a graph is to lower the order of large numbers
Primer.sm (8.51 KiB) downloaded 1072 time(s).
#3 Posted: 2022/3/13 12:32:01
598 likes in 1,380 posts.
You can make a function to draw circles, for multiple usage on same sheet.
With respect to Ber7, dividing it to MPa will lower the numbers too.
MSS.sm (7.3 KiB) downloaded 1119 time(s).
#4 Posted: 2022/3/13 22:37:25
Blackbambi
Blackbambi
0 likes in 3 posts.
Thank you all. I appreciate your help
#5 Posted: 2022/3/14 13:06:17
1,355 likes in 2,271 posts.
Here is a version with pre-defined geometric object in the XY plot plugin. See Handbuch section 8.3.4.
MSS_Kr.sm (13.86 KiB) downloaded 1119 time(s).
#6 Posted: 2022/3/14 14:11:02
Circle de Mohr.sm (47.02 KiB) downloaded 1115 time(s).
#7 Posted: 2022/3/15 04:28:27
Blackbambi
Blackbambi
0 likes in 3 posts.
Thank you for sharing your work
#8 Posted: 2022/3/15 09:42:51
There are many ways to plot circles wrt applications.
My most used brew ... Cheers, Jean.
Page4 Circles_Ellipses.sm (9.36 KiB) downloaded 1226 time(s).
#9 Posted: 2022/3/15 13:22:17
It is much easier to draw circles with X-Y Plot plugin.
circle_xy.sm (5.23 KiB) downloaded 1166 time(s).
#10 Posted: 2022/3/20 15:38:42
My most used brew
I prefer incremental discretizer.
Circle [QUICK,oblate_prolate].sm (14.23 KiB) downloaded 911 time(s).
