divide by zero error
divide by zero error - Messages
#1 Posted: 2020/1/31 09:46:08
Ale16595
Ale16595
0 likes in 35 posts.
Hello to all.
I have a problem with the Smath function "dn_GearsBDF", it blocks the operation since giving me division by zero error.
How can I overcome this problem? MANOVRA (con parametri moto).sm (78.83 KiB) downloaded 1029 time(s).
#2 Posted: 2020/1/31 10:11:20
In dn_GearsBDF(init,0,end,100,D(x,Y)) replace zero with a small positive number (say 10^-10)
#3 Posted: 2020/1/31 12:14:51
Ale16595
Ale16595
Hi, thanks for the reply.
Instead if I have an error like: "value too big or too small for an Int32", how can I solve it?
Every time this error appears the program stops.
MANOVRA slalom (cinematica).sm (45.07 KiB) downloaded 1106 time(s).
#4 Posted: 2020/1/31 12:54:54
Always separate text from image or *.sm document,
as you did: can't reply quote !
#5 Posted: 2020/1/31 13:12:46
1,355 likes in 2,271 posts.
10^10 was probably too small, you have to see, how small x can be for your derivative ψ''(x) still being defined. 0.01 works.
#6 Posted: 2020/1/31 14:30:34
... doctoring starts at red ... observe removing 10^14 at some trig [0].
lot more cleanup below ... can you write λ instead of l
MANOVRA slalom (cinematica).sm (52.94 KiB) downloaded 1024 time(s).
