Matrix Treasury
Matrix Treasury - Matrix Treasury - Messages
#1 Posted: 2015/12/19 23:13:06
There is more, working with matrices [3D, PseudoInverse ...]
Just a RemToDo.
The "Matrix Editor" Ecxel style is lovely, indeed.
At the end of this compendium, you will find a much
superior tool, directly from Smath, just make it
resident in the project work sheet and keep going.
Utilities Matrix Treasury.sm (284.57 KiB) downloaded 1353 time(s).
Radovan Omorjan 2015/12/20 05:58:00, ioan92 2015/12/20 07:08:00
#2 Posted: 2015/12/21 15:49:09
... few more under construction.
I noticed something terribly grave while working the main sheet.
Explain: while working, Some "illegal" code [apparently], Smath toke
... very happy working well. Bad luck, on closing the work sheet
it zapped the entire work [turn it all blank at reopening]. Oh ! Hell
Good think, most of it I could recuperate from previous attached.
Any fellow experienced such a nightmare ?
I Underatand, it's a big chunck for Smath, but peanut Mathcad 11
I still have a 100 MB Mathcad 11 WS [graciously made dead by PTC]
Comments/suggestion/typos: always appreciated
Utilities Matrix Treasury [Locate Matrix].sm (21.92 KiB) downloaded 1143 time(s).
Utilities Matrix Treasury [Rotate].sm (48.29 KiB) downloaded 1113 time(s).
Utilities Matrix Treasury.sm (307.74 KiB) downloaded 1391 time(s).
Radovan Omorjan 2015/12/21 17:48:00, ioan92 2015/12/21 18:56:00, Davide Carpi 2015/12/21 20:31:00
#3 Posted: 2015/12/21 17:48:51
... defending the use of the "Matix Editor" conjointly to Smath is
"floccinaucinihilipilification" ... Does not belong to Navajo.
Utilities Matrix Pad [M,nc,nr].sm (18.04 KiB) downloaded 1135 time(s).
#4 Posted: 2015/12/21 20:45:51
1,443 likes in 2,935 posts.
Nice work, as usual
Unfortunately, this happens...
I've made this proposal, anyone who want to support/improve it, you have to register in the Bug Tracker System.
BTW seems you have found something that I have to change...
2015-12-22 00_30_50-SMath Studio Desktop - [Utilities%20Matrix%20Treasury.sm_].png
#5 Posted: 2015/12/22 11:51:20
Thanks Davide for visiting and commenting. The "Why not nested" is simply because on closing,
either XP or Smath don't save the work sheet settings, completely.
I know about Autocad "AutoSave" but don't use AutoCad.
In my case, I didn't try XP Restore because of the time inprecision: it might have done nothing !
On delicate work sheets like "Matrix Treasury" I also save as copy,,, that one was scrapped too !
Your "AutoSave" proposal [link above] is quite welcome. Now convince Smath Developpers.
