1 Pages (4 items)
if_else Exception Report - if_else Exception Report - Messages
Can't make it work ... SS 6179
Please, can you quick verdict: NOT compatible
or if possible doctor the patient ?
It may have to be constructed recursive style
Thanks in advance ... Jean
Spline Bspline FAILS.sm (66.5 KiB) downloaded 1266 time(s).
WroteCan't make it work ... SS 6179
Here's something that at least evaluates on 0.99.7030. One thing to note about your function.
There isn't a "return" statement in Smath programming. A program returns the last line entry by default. So to compensate, you have to assign values to a variable and pass that variable at the end. In this case I chose "ans".
I also used "cases" function to clean things up a bit.
Spline Bspline PASSES-alyles.sm (68.51 KiB) downloaded 1197 time(s).
I had an error some of the logic. Also updated to mimic graph that was attached.
Spline Bspline PASSES-alyles.sm (79.56 KiB) downloaded 1214 time(s).
Spline Bspline PASSES-alyles.pdf (266.43 KiB) downloaded 788 time(s).
WroteHere's something that at least evaluates on 0.99.7030. One thing to note about your function.
Thanks Grand Doctor Alyles ... works fine.
Will refresh soon ... Jean
1 Pages (4 items)
