1 страниц (4 вхождений)
if_else Exception Report - if_else Exception Report - Сообщения
Can't make it work ... SS 6179
Please, can you quick verdict: NOT compatible
or if possible doctor the patient ?
It may have to be constructed recursive style
Thanks in advance ... Jean
Spline Bspline FAILS.sm (66,5 КиБ) скачан 1430 раз(а).
WroteCan't make it work ... SS 6179
Here's something that at least evaluates on 0.99.7030. One thing to note about your function.
There isn't a "return" statement in Smath programming. A program returns the last line entry by default. So to compensate, you have to assign values to a variable and pass that variable at the end. In this case I chose "ans".
I also used "cases" function to clean things up a bit.
Spline Bspline PASSES-alyles.sm (68,51 КиБ) скачан 1371 раз(а).
I had an error some of the logic. Also updated to mimic graph that was attached.
Spline Bspline PASSES-alyles.sm (79,56 КиБ) скачан 1379 раз(а).
Spline Bspline PASSES-alyles.pdf (266,43 КиБ) скачан 900 раз(а).
WroteHere's something that at least evaluates on 0.99.7030. One thing to note about your function.
Thanks Grand Doctor Alyles ... works fine.
Will refresh soon ... Jean
