1 Pages (6 items)
Thiele Function Automation - Automation of the Thiele function - Messages
This example is an automation of the Thiele function
published by Jean in the "Utilities Pts logpts Application" sheet
Thiele_Automatic_Jean_cbg.sm (22.08 KiB) downloaded 1106 time(s).
Carlos
Carlos
WroteThis example is an automation of the Thiele function
... refreshed a bit, a note added.
Superb, the piece of automated interpolation.
Thanks Carlos ... Jean
Thiele_Automatic_Jean_cbg.sm (26.85 KiB) downloaded 1114 time(s).
Hello Jean,
Please review the following example that you posted.
Thiele Model Construct.sm (44.15 KiB) downloaded 1121 time(s).
Thank you
Carlos
Thank you
Carlos
WroteHello Jean,
Hello Carlos,
The attached document has been doctored.
The long native form is as nice to export than the reduced J_Frac.
J_Frac is more compact, but not as clear for unfamiliar user.
Thiele is capricious wrt to Maple [see the blue note].
It starts refusing if too many Maple instances have been invoked,
maybe a limited courtesy from Maplesoft ?
Please let me know if correct in your Smath system.
See you soon ... Jean
From fresh Smath session, supports the 3 documents attached.
Thiele_0 Demo.sm (57.41 KiB) downloaded 1093 time(s).
Thiele Transit_Convert.sm (13.57 KiB) downloaded 1101 time(s).
Thiele Model Construct Copy.sm (37.77 KiB) downloaded 1106 time(s).
Hello Jean
Updated version of Interpolation using the Thiele algorithm in cuntinuous fractions.
It includes the calculation of the inverse differences φ [x0, ..., xi], obtained from the values in the known points
Rounding the values of the inverse differences for the purpose of presenting the equation to make it shorter
Thiele_Automatic_Jean_CBG_R1.sm (69.59 KiB) downloaded 1149 time(s).
Carlos
Carlos
Hello Carlos,
What a delicious/educative/Engineering piece of work ... zillions thanks !
Reshaped a bit for first time readers.
Thiele_3 Automatic [on error Carlos].sm (36.97 KiB) downloaded 903 time(s).
1 Pages (6 items)
