Fractal Tree
Fractal Tree - a programme for displaying a fractal tree - Messages
#1 Posted: 2020/3/15 14:48:37
Gerard Bush
Gerard Bush
8 likes in 9 posts.
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7.93 KiB) downloaded 1203 time(s).
fractal tree.pdf (209.83 KiB) downloaded 751 time(s).
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Davide Carpi 2020/3/16 12:19:00
#2 Posted: 2020/3/15 18:30:25
Like this ... in ½ points.
fractal tree.sm (11.31 KiB) downloaded 1199 time(s).
#3 Posted: 2020/3/16 07:13:02
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17.6 KiB) downloaded 1148 time(s).
Gerard Bush 2020/3/16 08:25:00, Davide Carpi 2020/3/16 12:19:00
#4 Posted: 2020/3/16 08:16:56
Gerard Bush
Gerard Bush
8 likes in 9 posts.
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18.39 KiB) downloaded 1143 time(s).
#5 Posted: 2020/3/16 09:04:22
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
In the program Jean I added the growth of the tree
Pattern fractal 1.sm (12.54 KiB) downloaded 1141 time(s).
5 users liked this post
Davide Carpi 2020/3/16 12:19:00, Alvaro 2020/3/17 16:15:00, Вячеслав Мезенцев 2020/3/16 13:59:00, frapuano 2020/3/16 09:35:00, Gerard Bush 2020/3/16 10:55:00
#6 Posted: 2020/3/16 17:55:35
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11.2 KiB) downloaded 1152 time(s).
Pattern Frieze Heppi.sm (11.97 KiB) downloaded 1173 time(s).
Pattern Hilbert.sm (8.53 KiB) downloaded 1129 time(s).
Pattern Patch Work.sm (10.92 KiB) downloaded 1153 time(s).
Pattern Fractal Sierpinski.sm (10.92 KiB) downloaded 1188 time(s).
Pattern Snail.sm (26.85 KiB) downloaded 1172 time(s).
Pattern Fern.sm (19.4 KiB) downloaded 1177 time(s).
Pattern Sierpinski Kover.sm (16.72 KiB) downloaded 1167 time(s).
Pattern Etoile Magic [Short].sm (46.69 KiB) downloaded 960 time(s).
Pattern Sierpinski Triangles.sm (35.21 KiB) downloaded 1149 time(s).
Pattern Prototile.sm (116.5 KiB) downloaded 1207 time(s).
#7 Posted: 2020/3/16 17:59:14
Pattern PythagorasTree.sm (6.99 KiB) downloaded 1184 time(s).
#8 Posted: 2020/3/17 15:24:27
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11.03 KiB) downloaded 958 time(s).
Gerard Bush 2020/3/18 09:56:00
#9 Posted: 2020/3/18 09:58:54
Gerard Bush
Gerard Bush
8 likes in 9 posts.
Thank you very much, Jean and Ber7 for your additions!
#10 Posted: 2020/3/18 12:06:31
Fridel Selitsky
Fridel Selitsky
Fractal tree with leaves
Pattern fractal 3.sm (12.01 KiB) downloaded 1149 time(s).
Davide Carpi 2020/3/18 15:07:00, Gerard Bush 2020/3/18 16:59:00, NDTM Amarasekera 2020/3/19 06:03:00
