Fractal Tree
Fractal Tree - a programme for displaying a fractal tree - Сообщения
#1 Опубликовано: 15.03.2020 14:48:37
Gerard Bush
Gerard Bush
8 сообщений из 9 понравились пользователям.
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7,93 КиБ) скачан 1390 раз(а).
fractal tree.pdf (209,83 КиБ) скачан 862 раз(а).
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Davide Carpi 16.03.2020 12:19:00
#2 Опубликовано: 15.03.2020 18:30:25
Like this ... in ½ points.
fractal tree.sm (11,31 КиБ) скачан 1383 раз(а).
#3 Опубликовано: 16.03.2020 07:13:02
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17,6 КиБ) скачан 1319 раз(а).
Gerard Bush 16.03.2020 08:25:00, Davide Carpi 16.03.2020 12:19:00
#4 Опубликовано: 16.03.2020 08:16:56
Gerard Bush
Gerard Bush
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18,39 КиБ) скачан 1318 раз(а).
#5 Опубликовано: 16.03.2020 09:04:22
Fridel Selitsky
Fridel Selitsky
In the program Jean I added the growth of the tree
Pattern fractal 1.sm (12,54 КиБ) скачан 1322 раз(а).
Davide Carpi 16.03.2020 12:19:00, Alvaro 17.03.2020 16:15:00, Вячеслав Мезенцев 16.03.2020 13:59:00, frapuano 16.03.2020 09:35:00, Gerard Bush 16.03.2020 10:55:00
#6 Опубликовано: 16.03.2020 17:55:35
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11,2 КиБ) скачан 1332 раз(а).
Pattern Frieze Heppi.sm (11,97 КиБ) скачан 1355 раз(а).
Pattern Hilbert.sm (8,53 КиБ) скачан 1308 раз(а).
Pattern Patch Work.sm (10,92 КиБ) скачан 1345 раз(а).
Pattern Fractal Sierpinski.sm (10,92 КиБ) скачан 1372 раз(а).
Pattern Snail.sm (26,85 КиБ) скачан 1355 раз(а).
Pattern Fern.sm (19,4 КиБ) скачан 1364 раз(а).
Pattern Sierpinski Kover.sm (16,72 КиБ) скачан 1341 раз(а).
Pattern Etoile Magic [Short].sm (46,69 КиБ) скачан 1144 раз(а).
Pattern Sierpinski Triangles.sm (35,21 КиБ) скачан 1327 раз(а).
Pattern Prototile.sm (116,5 КиБ) скачан 1408 раз(а).
#7 Опубликовано: 16.03.2020 17:59:14
Pattern PythagorasTree.sm (6,99 КиБ) скачан 1375 раз(а).
#8 Опубликовано: 17.03.2020 15:24:27
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11,03 КиБ) скачан 1127 раз(а).
Gerard Bush 18.03.2020 09:56:00
#9 Опубликовано: 18.03.2020 09:58:54
Gerard Bush
Gerard Bush
Thank you very much, Jean and Ber7 for your additions!
#10 Опубликовано: 18.03.2020 12:06:31
Fridel Selitsky
Fridel Selitsky
Fractal tree with leaves
Pattern fractal 3.sm (12,01 КиБ) скачан 1335 раз(а).
Davide Carpi 18.03.2020 15:07:00, Gerard Bush 18.03.2020 16:59:00, NDTM Amarasekera 19.03.2020 06:03:00
