Plotting Sine fuction
Plotting Sine fuction - Messages
#1 Posted: 2018/5/7 13:44:59
vijaykhatri
vijaykhatri
1 likes in 23 posts.
Can someone share an example of plotting a basic sine wave as a function of time.
I am running into some difficulties with the graphing part.
Vijay Khatri
#2 Posted: 2018/5/7 14:36:22
Arie
Arie
94 likes in 285 posts.
Have you had a look at the wiki here: https://smath.info/wiki/Graphs.ashx
Also take a look at the Interactive SMath Handbook put together by Martin. You can find it by going to tools ->Plugins then clicking on Interactive Books in the left panel. I cannot remember if it's installed by default or not. If it's not there you can download it by further clicking on the "Local Storage" button and selecting "Online Gallery" and choosing to install it from there.
#3 Posted: 2018/5/7 22:47:15
vijaykhatri
vijaykhatri
Thank You
#4 Posted: 2018/5/7 23:28:16
... a bit more.
Utilities Pts Split-in-range [a,b,N].sm (14.17 KiB) downloaded 554 time(s).
#5 Posted: 2018/5/9 11:21:08
vijaykhatri
vijaykhatri
Hi All,
I have a question related to the plotting, it miight be very trivial but I can't seem to figure it out. In the attached file, Basic_sine.sm (7.99 KiB) downloaded 635 time(s).I have used similar approach in MathCad and it works, however in SMath it does not.
Vijay
#6 Posted: 2018/5/9 11:44:36
Arie
Arie
Looks like you need to multiply omega by the unit 's (This makes the input to the sine function unitless). The standard sin() function doesn't seem to like units. I'm not sure if this is a bug or not. Note that 'deg is actually unit-less (it's simply a scale factor)
Basic_sine[1].sm (8.91 KiB) downloaded 596 time(s).
Edit: I'm fairly certain it's not a bug. Inputs to trig functions with any format other than radians or degrees is meaningless.
#7 Posted: 2018/5/9 12:46:11
vijaykhatri
vijaykhatri
Thank you
