Summation error - imaginary i as sum iterator
Summation error - imaginary i as sum iterator - Changed summation behaviour? - Messages
#1 Posted: 2018/3/18 17:55:24
Jan Claeys
Jan Claeys
2 likes in 25 posts.
Dear all,
Some years ago, I worked out a beam calculation tool in smath, based on singularity functions.
The sheet worked flawless in an older SMath version, but the most recent SMath-incarnations result in problems: the error seems to originate with the summation command.
How do I get this program working again?
I attach the original files: thanks for any feedback!
Kind regards from a Belgian SMath-fan,
Jan
Original file with summation error.sm (143.1 KiB) downloaded 741 time(s).
Original file working.pdf (190.36 KiB) downloaded 402 time(s).
#2 Posted: 2018/3/18 18:25:11
2,315 likes in 3,949 posts.
Hello.
This is because of using "i" as a variable. Currently we have some issues regarding it. Will be addressed soon.
Simple change to fix your worksheet:
janclaeys 2018/3/19 08:16:00
#3 Posted: 2018/3/19 00:27:26
Hello.
Alternately: define the summations as local variable [SS 6179]
The document concludes the project.
Original file with summation error(1).sm (147.86 KiB) downloaded 699 time(s).
#4 Posted: 2018/3/19 08:16:29
Jan Claeys
Jan Claeys
Thank you Andrei & Jean for the fast feedback!
