1 Pages (12 items)
Solve with 4 args - Is it a bug? - Messages
Hi Valery. It seems that solve doesn't know how to order the interval.
The 6 solutions numerically
And symbolically
solve(4).sm (158.3 KiB) downloaded 674 time(s).
And symbolically
Edited 2026/7/17 07:28:06
Hi Valery. Two ways.
heart area.sm (13.36 KiB) downloaded 619 time(s).
Mathcad 11:
mc11 double int.mcd (4.77 KiB) downloaded 610 time(s).
Mathcad 11:
Edited 2026/7/25 17:52:57
Valery Ochkov 2026/7/25 18:27:25
It's possible, although speed isn't one of SMath's main features. And with so few points, there isn't much accuracy.
heart area.sm (26.99 KiB) downloaded 613 time(s).
Valery Ochkov 2026/7/26 13:14:28
I can write a function that returns a set of closed isolines. The area can be calculated from the points on the curve. To construct implicit graphs, a function is used that returns the coordinate sets of the found isolines.
WroteI can write a function that returns a set of closed isolines. The area can be calculated from the points on the curve. To construct implicit graphs, a function is used that returns the coordinate sets of the found isolines.
Вячеслав, привет!
Брось все силы на создание инструментов оптимизации с ограничением типа Given... Minimize/Maximize в Mathcad 15. Этого очень не хватает в SMath.
И Андрей на это настроен.
Using Dragilev Method.
Area and Arc Length of an Implicit Planar Closed Curve - Dragilev Method.sm (16.28 KiB) downloaded 603 time(s).
Edited 2026/7/27 01:33:24
Yes, something like this with the Gaussian area formula.
ioan92 2026/7/28 11:13:51
WroteYes, something like this with the Gaussian area formula.
Hi Viacheslav. In that case, I'd like to point out that dividing by the norme (Δ) means the curve is parameterized with respect to arc length, and that if you're going to improve the points using the original function, you must also do so with the parameter variable, which in the program's notation is T. This is because Dragilev's method ultimately obtains the parametric expressions x(t) and y(t) from the implicit function f(x,y) when starting from a point (xo,yo) on the curve.
This is one way to correct the arc length given by T if you choose to improve the curve points, although there must be better methods involving splines for curves in the plane, not just single-valued functions. There are also better approximations for the area enclosed by the curve; the one used here is simply the area defined by a closed polygon.
Area and Arc Length of an Implicit Planar Closed Curve - Dragilev Method.sm (17.78 KiB) downloaded 91 time(s).
Edited 2026/7/28 08:36:40
Valery Ochkov 2026/7/28 16:17:18
1 Pages (12 items)
.png)
