SMath Studio on Linux
SMath Studio on Linux - Сообщения
#1 Опубликовано: 08.02.2023 19:55:53
Oichi
Oichi
4 сообщений из 35 понравились пользователям.
I downloaded SMath Studio AppImage from the website on ubuntu 22.04. Whenever I open it, it loads that green loading box attached below then it crashes. Any help please?. Thanks in advance
#2 Опубликовано: 09.02.2023 08:28:22
599 сообщений из 1 380 понравились пользователям.
Try to run with sudo.
Whether appimage or regular, it won't run without sudo.
Well it will, but you must try a lot of times to make it run.
A link to a thread for further examination
This is a mono bug specific to debian distros except for one.
It is related with glibc and kernel version I suppose.
As far as I know due to my experience, only Debian based
distro I could run SMath without sudo is MXLinux (ahs).
If SMath doesn't run even, please run it under a terminal.
And post terminal output here, maybe it is a faulty plugin.
#3 Опубликовано: 12.12.2023 18:51:26
mocarny_knur
mocarny_knur
I created account on this forum only to write that if You install in Ubuntu 22.04:
libmono-cil-dev
libmono-db2-1.0-cil
mono-dbg
mono-devel
mono-tools-devel
then it should work without sudo. This is some bug within mono and installing mono debugging allows it to run apparently.
#4 Опубликовано: 15.09.2024 02:33:00
usamakhan
usamakhan
6 сообщений из 93 понравились пользователям.
I am running SMath on my OrangePi-3b arm64 so far so good. Can anyone tell me how to use GTK themes for mono applications. SMath looks ugly
#5 Опубликовано: 16.09.2024 00:49:21
Especially if your theme is dark for linux, SMath becomes unusable.
Buttons can't be seen, toolbars are too dark, etc.
So I edit smathstudio_desktop_mono file as below.
#!/bin/sh
HERE="$(dirname "$(readlink -f "${0}"""
cd "${HERE}"
export MONO_WINFORMS_XIM_STYLE=disabled; GTK2_RC_FILES=/usr/share/themes/Raleigh/gtk-2.0/gtkrc exec mono "${HERE}//Solver.exe" "$@"
I use smath with a light default theme from /usr/share/themes/.
WINFORMS option also fixes ubuntu/debian crash.
#6 Опубликовано: 16.09.2024 09:41:19
usamakhan
usamakhan
Thanks Overlord, the thing is that developers should move from MONO to dotnet6/7/8 these are available in all Linux distributions! Recently a popular photo editor Pinta moved from MONO to dotnet8 ...similarly calcpad also did that & is very usable in Linux
Davide Carpi 16.09.2024 13:31:00
#7 Опубликовано: 16.09.2024 16:12:13
Actually, not every distribution has dotnet in their repository.
Some major ones like fedora or ubuntu have it, but rest doesn't.
#8 Опубликовано: 17.09.2024 07:33:38
usamakhan
usamakhan
overlord, I did that (customised run script) but Rayleigh theme was not loaded. I tested location / files ...content is there but theme is not loaded. Any suggestions?
#9 Опубликовано: 17.09.2024 18:15:18
If smath window is light themed, it should have ben loaded.
As far as I know, mono2 applications doesn't accept themes designs except colors.
#10 Опубликовано: 06.10.2026 02:17:22
usamakhan
usamakhan
In 2026; I still face x5 year old issue https://smath.info/en-US/forum/topic/CmDw2o/Some-little-anomalies-on-linux https://smath.info/en-US/forum/topic/WhzbAL/Bad-behaving-without-installed-fonts
Luckily this script / font resources will correct everything https://www.mediafire.com/file/apzsx0mi01qi55r/smath_linux_font_bug.7z/file
#11 Опубликовано: 07.10.2026 11:52:09
That's nice to see actual solutions. Would be better for inspection and long term accesss to upload your package in a repository (our SVN or a public GIT repo).
Отредактировано 07.10.2026 11:53:18
#12 Опубликовано: 20.10.2026 23:14:06
usamakhan
usamakhan
Previous Font bug and detailed solution hosted on GitHub: https://github.com/defencedog/smath-devel/tree/main/font-pack
Print preview bug and CUPS virtual printer producing blank pages solved at: https://github.com/defencedog/smath-devel/tree/main/print-patch
