SMath Studio on Linux
SMath Studio on Linux - Messages
#1 Posted: 2/8/2023 7:55:53 PM
Oichi
Oichi
4 likes in 35 posts.
I downloaded SMath Studio AppImage from the website on ubuntu 22.04. Whenever I open it, it loads that green loading box attached below then it crashes. Any help please?. Thanks in advance
#2 Posted: 2/9/2023 8:28:22 AM
599 likes in 1,380 posts.
Try to run with sudo.
Whether appimage or regular, it won't run without sudo.
Well it will, but you must try a lot of times to make it run.
A link to a thread for further examination
This is a mono bug specific to debian distros except for one.
It is related with glibc and kernel version I suppose.
As far as I know due to my experience, only Debian based
distro I could run SMath without sudo is MXLinux (ahs).
If SMath doesn't run even, please run it under a terminal.
And post terminal output here, maybe it is a faulty plugin.
#3 Posted: 12/12/2023 6:51:26 PM
mocarny_knur
mocarny_knur
0 likes in 1 posts.
I created account on this forum only to write that if You install in Ubuntu 22.04:
libmono-cil-dev
libmono-db2-1.0-cil
mono-dbg
mono-devel
mono-tools-devel
then it should work without sudo. This is some bug within mono and installing mono debugging allows it to run apparently.
#4 Posted: 9/15/2024 2:33:00 AM
usamakhan
usamakhan
6 likes in 93 posts.
I am running SMath on my OrangePi-3b arm64 so far so good. Can anyone tell me how to use GTK themes for mono applications. SMath looks ugly
#5 Posted: 9/16/2024 12:49:21 AM
Especially if your theme is dark for linux, SMath becomes unusable.
Buttons can't be seen, toolbars are too dark, etc.
So I edit smathstudio_desktop_mono file as below.
#!/bin/sh
HERE="$(dirname "$(readlink -f "${0}"""
cd "${HERE}"
export MONO_WINFORMS_XIM_STYLE=disabled; GTK2_RC_FILES=/usr/share/themes/Raleigh/gtk-2.0/gtkrc exec mono "${HERE}//Solver.exe" "$@"
I use smath with a light default theme from /usr/share/themes/.
WINFORMS option also fixes ubuntu/debian crash.
#6 Posted: 9/16/2024 9:41:19 AM
usamakhan
usamakhan
Thanks Overlord, the thing is that developers should move from MONO to dotnet6/7/8 these are available in all Linux distributions! Recently a popular photo editor Pinta moved from MONO to dotnet8 ...similarly calcpad also did that & is very usable in Linux
Davide Carpi 9/16/2024 1:31:00 PM
#7 Posted: 9/16/2024 4:12:13 PM
Actually, not every distribution has dotnet in their repository.
Some major ones like fedora or ubuntu have it, but rest doesn't.
#8 Posted: 9/17/2024 7:33:38 AM
usamakhan
usamakhan
overlord, I did that (customised run script) but Rayleigh theme was not loaded. I tested location / files ...content is there but theme is not loaded. Any suggestions?
#9 Posted: 9/17/2024 6:15:18 PM
If smath window is light themed, it should have ben loaded.
As far as I know, mono2 applications doesn't accept themes designs except colors.
#10 Posted: 10/6/2026 2:17:22 AM
usamakhan
usamakhan
In 2026; I still face x5 year old issue https://smath.info/en-US/forum/topic/CmDw2o/Some-little-anomalies-on-linux https://smath.info/en-US/forum/topic/WhzbAL/Bad-behaving-without-installed-fonts
Luckily this script / font resources will correct everything https://www.mediafire.com/file/apzsx0mi01qi55r/smath_linux_font_bug.7z/file
#11 Posted: 10/7/2026 11:52:09 AM
1,443 likes in 2,936 posts.
That's nice to see actual solutions. Would be better for inspection and long term accesss to upload your package in a repository (our SVN or a public GIT repo).
Edited 10/7/2026 11:53:18 AM
#12 Posted: 10/20/2026 11:14:06 PM
usamakhan
usamakhan
Previous Font bug and detailed solution hosted on GitHub: https://github.com/defencedog/smath-devel/tree/main/font-pack
Print preview bug and CUPS virtual printer producing blank pages solved at: https://github.com/defencedog/smath-devel/tree/main/print-patch
