Stable: SMath Studio 0.98.6128 (11 October 2016) - Сообщения
Скачать
SMathStudioDesktop.0_98_6128.Mono.tar.gz (1,23 МиБ) скачан 4163 раз(а).
SMathStudioDesktop.0_98_6128.Setup.msi (2,09 МиБ) скачан 21380 раз(а).
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
- [SS-93]: Multiple decimal symbols allowed in variable name now;
Could you please allow both "." and "," to be used and shown as-is in second and following cases in names?
First one, of course, should continue to be converted to "." regardless of which character was used, because otherwise that invisible character (used to create "subscript") may create two different variables that look identically.
But subsequent colons and dots are visible, and thus may be used as is, to avoid different name display depending on current decimal separator, and to enable using intended character (like in Xa,b - here a and b used as list; Xmin.h - here dot is used as separator, and colon would look worse).
WroteCould you please allow both "." and "," to be used and shown as-is in second and following cases in names?
All three symbols (.,
- front-end: triggers arguments separators, if the argument separator symbol is allowed as separator in the subscript;
- back-end: drive properly the plain text;
- back-end: localization conversion (I mean, a.b,c with standard settings should be converted to a,b;c when decimal symbol is set to comma and semicolon is used as argument separator);
2nd and 3rd point can be driven using alternative characters that looks like the others ("greek question mark" ; [U+037E] / "single low-9 quotation mark" ‚ [U+201A] / "small full stop"﹒[U+FE52]
for the first point I guess the only way is to use some shortcut key.
o_o
Can you share some info about your system? (Operative System, DPI); it appears always or only in some case (new worksheets, existing worksheets)? a clean install might help?
Thank you!
See please the attached file. I have no idea why the famous "i" variable made a mess here
i_problem.sm (20,05 КиБ) скачан 1735 раз(а).
WroteSee please the attached file. I have no idea why the famous "i" variable made a mess here
It does not make mess 5346.
FindRoots [Φ.o] looks under defined wrt Maxima that needs a function
whereas it is not a "root". A "root" crosses the X axis. Φ.o can be
anything in the Catesian plane. You can solve point by point but
NOT on a range. Mathcad 11 would not do either. You are in fact,
in other words, "inversing a function". The Mathcad way is the
"seeded root scanner" over a prescribed discrete range ...
as fast as a lighting strike !!!
Cheers Radovan: Jean
Radovan_2.sm (14,96 КиБ) скачан 1816 раз(а).
Radovan_1.sm (27,28 КиБ) скачан 1737 раз(а).
The attached is the Smath 5346 "iterative root scanner". It works but
can't be made "seeded". It re-solves from the starting point. Thus
takes several seconds instead of ~ 0 second if it would keep solving
from the last calculated value [seeded to last value].
I bet there is a twist, but just RemToDo.
In some way, I abandoned because of solving the "data set companion"
not possible in Smath whereas it does not have the Mathcad Given/Find
equivalent.
Solve INVERSE Mathematica.sm (9,54 КиБ) скачан 1790 раз(а).
WroteIt seems that "i" still causes some headaches. I used a part of one of my standard files and get this rather strange error message
It is not about i, there is a bug in preprocessing wrt the iterator argument of sum() when unknowns are involved in other arguments on definitions; the iterator name is replaced with a value, then when sum tries to evaluate the name is lost.
![2016-10-18 12_42_45-SMath Studio - [iterator arg.sm].png](/ru-RU/files/Download/oYcxKE/2016-10-18-12_42_45-SMath-Studio---[iterator-arg.sm].png)
iterator arg.sm (7,93 КиБ) скачан 1716 раз(а).
I was quite close to figure this out, but failed. Fortunately, it is not about "i".
Wish you all the best,
Carlos
iterator arg_CBG.sm (8,35 КиБ) скачан 1683 раз(а).
WroteThank you Davide
Smath 5346 does not suffer the bug that Davide has isolated.
Attached is your project as far as I understand.
Takes 5 min to compute all 35 "Sol" . Works well.
RemToDo: the seeded "solve", I have an idea ?
Cheers, Jean
Forum Radovan_1.sm (40,81 КиБ) скачан 1685 раз(а).
