at function in SMath
at function in SMath - Сообщения
#1 Опубликовано: 07.06.2023 11:25:18
NDTM Amarasekera
NDTM Amarasekera
Hello!
What is the advantage of at function in SMath ?
Appreciate if any useful example is provided.
Cheers !
#2 Опубликовано: 07.06.2023 12:34:30
Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the 'eval' in maple, although it also has a 'subs' function, and even another one like 'algsubs', or Mathematica's f /. x -> a notation, and perhaps there you can see how those programs use it and get a better idea of what it might be useful for. I also remember that den derive, which did not have a function like at, could be used instead ... take the limit: lim f for x -> a
#3 Опубликовано: 07.06.2023 14:01:37
NDTM Amarasekera
NDTM Amarasekera
Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the 'eval' in maple, although it also has a 'subs' function, and even another one like 'algsubs', or Mathematica's [b]f /. x -
Hi Alvaro, thank you very much for your kind sentiments and valuable clarifications.
#4 Опубликовано: 07.06.2023 15:19:06
Handbook page for at() and Solve(). at() is a convenient alternative for Assign(), which creates assignments based on equations (as returned by Solve, ODE2 or Fit())
at.sm (22,23 КиБ) скачан 1373 раз(а).
_Solve.sm (33,17 КиБ) скачан 1394 раз(а).
#5 Опубликовано: 07.06.2023 16:48:46
Some demo application.
Take care ... Jean.
Solve at(2), at(3).sm (30,21 КиБ) скачан 1366 раз(а).
#6 Опубликовано: 07.06.2023 18:04:21
Electron function added Φ(x,y)
This function has no symbolic solution.
It plots X_Y but for QuickPlot, you need solving.
Solve at(2), at(3).sm (47,5 КиБ) скачан 1408 раз(а).
#7 Опубликовано: 07.06.2023 23:33:01
NDTM Amarasekera
NDTM Amarasekera
Thank you all for the clarifications and examples
