Disable specific unit
Disable specific unit - How to disable not used unit - Сообщения
#1 Опубликовано: 23.04.2018 10:18:16
m227
m227
4 сообщений из 29 понравились и 1 не понравились пользователям.
Hi, in my calculations I often use kJ/kg (and derivative) units (enthalpy, specific heat).
SMath always presents result in Gy and I have always manually to redefine it.
Is there any possibility to disable Gy unit which is useless for my tasks?
I tried to assign 'Gy := 0 to disable this unit but it does not work.
#2 Опубликовано: 23.04.2018 10:42:17
Work sheet would help.
Unitless solves all problems.
Knowing in advance the unit of result, define it user style
kJ/kg ... Smath style kJ_kg:=1
copy "kJ_kg", paste in the empty place holder of result.
#3 Опубликовано: 23.04.2018 13:09:38
Ruben Sidranski
Ruben Sidranski
When you re-defined Gy, did you use the ' infront of Gy (e.g. 'Gy? This makes it the same font/etc.
I work in IP units and need to re-define everything in the results. Part of the quirks of working in SMath
#4 Опубликовано: 23.04.2018 14:40:46
#5 Опубликовано: 27.04.2018 07:38:08
m227
m227
Hi, I would like to have something without need of definition new auxiliary variables. Just to disable a single unit...
Here is my sample which is automatically recalculated to unwanted Gy:
#6 Опубликовано: 27.04.2018 08:45:21
btw, the default unit depends on optimization setting.
symbolic evaluation gives bare SI base units.
numeric evaluation gives some derived unit, which might or might not be appropriate for the given case.
#7 Опубликовано: 08.11.2018 03:44:26
Ganzman
Ganzman
I have to agree with m227. Can we request this as a feature as Gy is hardly applicable in most cases.
#8 Опубликовано: 08.11.2018 20:02:36
Hi. This is a workaround. Edit the file Units.xml under the SMath/entries/ folder, disabling the entries for the unit Gy:
Then you can get, for example, the enthalpy from Coolprops plugin in J/kg by default:
frapuano 09.11.2018 06:54:00
#9 Опубликовано: 08.11.2018 20:35:48
Ganzman
Ganzman
Much obliged!
