"Else" statement not appearing when I choose "if" from the programming pallete
"Else" statement not appearing when I choose "if" from the programming pallete - Problem using the if function from the programming pallete - Сообщения
#1 Опубликовано: 06.08.2022 12:59:16
James Mazon
James Mazon
I´m having problems with the if function on the programming pallete. When I choose "if" from the pallete it just shows two lines, there is no else anymore like on the image in the attachment. If I recall correctly the else statement used to automatically appear when you choose the "if" function from the pallete. Could someone help me understand what´s happening?
Показать спойлер
#2 Опубликовано: 06.08.2022 14:03:26
118 сообщений из 336 понравились пользователям.
First of all, check in Tools-Option-->Interface-->Arguments separators which setting you set up. They are possible "," "." ";".
Suppose it is ";".
In the placeholder digit once ";" to get Else or ";;" to get Elseif
#3 Опубликовано: 07.08.2022 12:12:44
James Mazon
James Mazon
Thank you! It worked
