Configuration management of SMath studios and worksheets
Configuration management of SMath studios and worksheets - How to configuration mange the set of SMath studios and worksheets? - Сообщения
#1 Опубликовано: 02.08.2019 05:59:55
MSL
MSL
1 сообщений из 22 понравились пользователям.
I have made many worksheets with severla SMath studio mono versions and specific plugins.
My problem is some of the plugins (Excel I/O etc.) are not supported and I got the some of errors during my opening the old worksheets.
I've downloaded old archived SMath studio version, and tried again but failed.
How could I freeze the SMath studio program, plugins and their worksheets?
Thank you for your kind help.
Best regards,
MS
#2 Опубликовано: 03.08.2019 05:21:25
You can use portable versions. Then all extensions are stored in the installation directory and you can have multiple smath installations side by side just having them in separate directories.
Essentially you have to create an empty file with name "portable.version" in the installation directory before downloading any extensions.
#3 Опубликовано: 05.08.2019 04:25:37
MSL
MSL
Thank you for the tip.
Are the The portable versions SMath mono versions?
All of my old mono versions archived could not plugin the "Excel I/O with recalculation and PNG" in these day.
I have no idea how to solve this problem.
M.S.
#4 Опубликовано: 05.08.2019 10:30:34
Arie
Arie
I don't think this plugin is still actively maintained. It may not work with recent versions of SMath.
#5 Опубликовано: 05.08.2019 16:46:36
You can try this version. Just replace the ExcelIOCom.dll file.
ExcelIOCom.7109.zip (9,41 КиБ) скачан 406 раз(а).
EDIT. I added this plugin to the gallery. Previously, it was not there, because it is very old. Unfortunately, this plugin will not work in Linux, as based on COM.
#6 Опубликовано: 06.08.2019 07:07:54
I made a mistake in the type of plugin. Now I understood what was meant. I will try to update this plugin as well.
