Variable with subscript and apostrophe.
Variable with subscript and apostrophe. - Сообщения
#1 Опубликовано: 17.07.2023 13:47:41
C DeVillier
C DeVillier
I need to create a variable labeled fc' to represent the compressive strength of concrete("f" and apostrophe being on the normal typing line, and "c" being treated as a subscript). From looking online I have come across round about ways of inputting similar variables using the Windows Character Map. Some characters are available in the character map that SMath will treat as a normal line of typing character, but the character displays as a subscript, such as U+2093: Latin Subscript Small letter X. Unfortunately, nothing is available for c.
Any help is appreciated.
Thanks
#2 Опубликовано: 17.07.2023 14:31:11
f apostrophe dot c
Show the image of your success !
#3 Опубликовано: 17.07.2023 18:54:54
As for now, the simplest way is to use f'.c (that is widely used too).
I know ACI 318 has f.c^’, but there is not yet a way to freely mix baseline/subscript/superscript characters (also, superscript characters are only the ones available from the unicode tables).
#4 Опубликовано: 18.07.2023 02:09:49
Hi. As Davide says, there are only some few characters for subscripting with Unicode chars. This is a workaround for this case and some others:
fc'.sm (4,71 КиБ) скачан 1486 раз(а).
#5 Опубликовано: 18.07.2023 16:44:30
... as you type f, you have 3 useful upper-script:
coma, Alt238, Alt248
and about 75 sub-script form AltKey
#6 Опубликовано: 20.07.2023 11:58:26
An arabic damma sign combined with latin f.
And two spaces to ensure it doesn't overlap.
Copy paste text below to smath.
Maybe this helps.
fُ.c\0020\\0020\
