[SS-3470] Derivative problem
[SS-3470] Derivative problem - Failing derivative function definition - Сообщения
#21 Опубликовано: 23.08.2017 12:51:17
Jan Claeys
Jan Claeys
2 сообщений из 25 понравились пользователям.
Hello Davide,
I can confirm that I still get the same error warning (just checked it): "Input string was not in a correct format". You'll see that no roots for the (simple) derivative function are found.
Plugins don't seem the reason: I run the latest version as portable app from an USB-stick since I'm no administrator on my work pc, and I replace every time the whole SMath directory.
Furthermore, no plugin functionality was used in the given files.
Kind regards,
Jan
Davide Carpi 23.08.2017 20:08:00
#22 Опубликовано: 23.08.2017 13:39:13
There has to be a program mistake somewhere?
"Result is above max allowed" has several meaning, most often complex result.
Examine the attached and the conclusion that derivative operator is incorrect.
Cheers, Jean
NOK expand.sm (29,56 КиБ) скачан 1267 раз(а).
#23 Опубликовано: 24.08.2017 08:06:11
Hello Davide,
Kind regards,
Jan
Thank you for this test. I've made some attempts and it seems a localization issue in the SS core. I'll fix it ASAP.
topic moved in the "Bugs & Problems" section.
#24 Опубликовано: 24.08.2017 09:50:32
Jan,
Let's make it clear: the program as you wrote regarding the project calculations,
you are the only expert, maybe the unit system make some big coefficients.
If you mean program mistake as Smath, there is no error, let me explain.
Two types of error were reported:
1. "input string was not in correct order" => this is a Win error message, what does it mean ?
In the symbolic expansion some elements are of the form "Power function" [X^Y]
This X^Y is built-in in Win and does not take those very high coefficients.
There is NOTHING to cure/rescue Win.
2. The other error "result is above max allowed" => this is an Smath error message, what it means ?
In the symbolic expansion, some of the coefficients are immensly long, they look 64 bits expansion
from which "Smath symbolic engine code" ??? Thus, Smath 32 bits can't process.
I say that from other problems encountered In Smath "result is above max allowed"
Smath does an extraordinary good job about Thiele fit methods. After the symbolic expansion,
some coefficients appear as fractions of so long num/den. For practical works and export a "formula"
we have to reduce these long num/den as simple number, thus simply copy the immense num/den
and equate to get a number. Generally it did work, when the num/den can be evaluated 32 bits.
I have encountered some num/den to immense [presumably 64 bits] with the error message
"result above max allowed" ... I found some reconciliation to these error message.
Unfortunately=> not yet wrt your project. I will revisit, but in the mean time if Smath
can't process the numerical coefficients => it can't process the derivative.
Simply deceptive but most interesting.
Smath has its own symbolic engine, that's what you see when you hover a function.
But when you command for the symbolic expansion [Ctrl+.] it seems to expand from
Maple symbolic, thus the 64 bits expansion.
