[LINUX] sm rc3 and before
[LINUX] sm rc3 and before - division by zero when saving and crash - Сообщения
#1 Опубликовано: 17.03.2016 04:16:12
ai shen
ai shen
1 сообщений из 18 понравились пользователям.
I left SM because on ubuntu it didn't work any more (cil winform no more on it)
I would like to see if its better working now with RC3 (the other have same problem)
I run the mono sm but doesen't start, then I run mono sm exe and it works... When loading a file everything is messed, when saving it crashes or says division by zero (for example sqrt(16) = 4 but saving doesn't work
Any help, I tried last ubuntu's 15.04 15.10 and 16.04 same problem.
Meanwhile I installed it on w10 virtualbox and works fine !
Thanks for this good soft hope we can get it back on linux
Henri
#2 Опубликовано: 17.03.2016 05:18:37
also not working on fully upgraded Arch Linux with Mono
#3 Опубликовано: 22.03.2016 18:58:17
Группа: Super Administrator
Cannot reproduce.
Just tested latest SMath Studio 0.98 (RC4) with latest Mono on fresh openSUSE. Everything works fine (complex worksheets, different plug-ins, etc.)
#4 Опубликовано: 01.04.2016 22:34:07
Ruben Sidranski
Ruben Sidranski
So I decided to jump onto the Linux foray this evening ... first time! Mint 17.3 XFCE on an old VISTA machine. I found instructions on how to install mono online.
Installed version 4.2.3.
I then downloaded the latest version (THANKS Andrey) and "unzipped (tar.gz?)" the the files into a public directory.
I then ran the desktop exe and it fired up! Doing good ...
Then I ran into a problem. I created a shortcut in the same folder where SMath is located and it opens ... BUT, when I move that shortcut to the desktop, nothing.
Again, first Linux experience, total newbie. Did I miss any Linux settings or is it a bug? I honestly think it's me, as the shortcut link works withing the SMath folder.
I'd take a picture, but don't know what "snipping tool" to use
