Wrong display of output units
Wrong display of output units - Сообщения
#1 Опубликовано: 18.10.2020 17:44:45
EngMath
EngMath
0 сообщений из 51 понравились пользователям.
I've just started using this software and I think that it's great. However, I came across an issue that may be a bug. Here's my input:
a := 0,1 m
b := 0,05 m
L := 1 m
M := 1000 Nm
τ_max := (2*M)/(π*a*(b^2)) =
Now in the last line I want to change units to MPa. But when I do it (by writing MPa in the right placeholder), I get the following result:
No matter what I try, I can't get rid of this part that I highlighted in red. I want to have just MPa on the right side. Is that a bug or am I doing something wrong ?
#2 Опубликовано: 18.10.2020 17:54:25
599 сообщений из 1 381 понравились пользователям.
Nothing is wrong.
Could you please check your expressions carefully?
#3 Опубликовано: 18.10.2020 17:59:32
Perhaps you are using 'Nm instead of 'N*'m
If you want you can define your own torque unit 'Nm:'N*'m before the calculations, otherwise you have to multiply the force unit fot the length unit
EngMath 30.05.2021 09:05:00
#4 Опубликовано: 18.10.2020 18:02:47
EngMath
EngMath
Problem solved, thank you very much. I had to type 'N*'m as you say because 'Nm wasn't recognized properly.
#5 Опубликовано: 10.11.2020 08:35:58
Int16
Int16
0 сообщений из 9 понравились пользователям.
How to compute this
#6 Опубликовано: 10.11.2020 12:20:49
The problem is due to the internal storage of the program in Kelvin. You find several threads in the forum. you can also find an explanation in Martin Kraska's interactive guide (Tools menu -> Options -> Plugins -> interactive books). However the solution is to use DeltaC °
Davide Carpi 12.11.2020 10:10:00
#7 Опубликовано: 12.11.2020 09:04:06
Int16
Int16
Thanks a lot.
#8 Опубликовано: 12.11.2020 10:30:53
... you can make the unit system silent, i.e: inactive
#9 Опубликовано: 13.11.2020 17:55:49
This is close to recommending pencil and paper.
#10 Опубликовано: 14.11.2020 08:49:14
Pretty close Martin, that's ± what QA sanity check does.
The mV/I temperature converter reads mV ... then displays °C.
In parallel to the black box mV/I, read mV, interpolate wrt NBS [now NIST].
#11 Опубликовано: 14.11.2020 14:24:48
wrong display of output units
You will have infinitely many of those, easy to doctor:
1. make the system silent, though not quite paper/pencil
2. make it user style at will.
